Old 04-27-2010, 04:09 PM
JBSPartans05's Avatar
JBSPartans05 JBSPartans05 is offline
Vehicle: 06' Dodge Ram 1500 4x4 HEMI
Trim Level: Big Horn Quad Cab
Rep:54
JBSPartans05 will become famous soon enough
Default Loose Tire Rod ??
When i went to get my truck balanced and aligned, they told me i had a loose tire rod and wants to charge $125 to fix it..
Is this reasonable ??
Also if it is loose how long can i go before i should really get this repair done..
Thanks
Joe East Lansing, Michigan
Dodge Ram 1500 Big Horn 4x4 5.7 L Hemi QWD!!
Old 04-27-2010, 04:13 PM
Rep:1909
Are they including and alignment/toe reset in that price and what brand parts do they intend to use? How long you can let it go depends on how loose it is but at worst, it could seperate and you could lose your steering.
Old 04-27-2010, 04:19 PM
Depends on which tie rod end their talking about . Some of the tie rods can be as cheap as $10.00 and as high as $88.00 .
Old 04-27-2010, 04:34 PM
Rep:2657
The tie rod transmits force from the steering center link or the rack gear to the steering knuckle. This will cause the wheel to turn. The outer tie rod end connects with an adjusting sleeve, which allows the length of the tie rod to be adjustable. This adjustment is used to set a vehicle’s alignment angle.
it maybe a bad tie rod end or something worse, but, it still a steering problem
a tie rod end can run between $30 - 60 & then there is the labor, if it was an alignment shop, they should know what they are doing
if it was real bad, they wouldn't have let you drive away with it, BUT, it should be done soon
Old 04-27-2010, 04:47 PM
Rep:2657
Joe, i found this on youtube, its not for your particular vehicle, but, it gives you a general idea about just replacing a tie rod end
Old 04-27-2010, 06:34 PM
Rep:54
Alright thanks guys.. Yea i got it done from Firestone since they had a Lifetime Alignment and Balancing.. for a reasonable price.
Just seemed expensive for just adjusting something
Old 04-27-2010, 07:11 PM
Rep:1909
A loose tie rod has to be replaced, not adjusted. The lifetime alignment makes it a good deal if they do it correctly.
