Old 04-27-2010, 07:52 PM
Jus's Avatar
Jus Jus is offline
Vehicle: 1999 Dodge Ram
Trim Level: ..uh..wut?
Color: electric blueee
Rep:12
Jus is on a distinguished road
Send a message via MSN to Jus
Default Scratched Headlights...repair possible?
alright i need to find out if i can repair heavy scratched up headlights?
any advice?
Old 04-27-2010, 08:19 PM
drivehard27's Avatar
drivehard27 drivehard27 is offline
Vehicle: 2012 dodge ram
Trim Level: sport
Rep:108
drivehard27 will become famous soon enoughdrivehard27 will become famous soon enough
Send a message via Yahoo to drivehard27
i would try a buffer and some toothpast yes toothpast it works just take a wax pad put some past on it rub it on and then wipe the heavy off then use a buffer on low i had a big scratch on my wifes car headlight and i took it out
2012 ram sport qc
Old 04-27-2010, 08:28 PM
Jus's Avatar
Jus Jus is offline
Rep:12
goin to try that right now
Old 04-27-2010, 08:36 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I have seen a few headlight renuew and scratch remover kits available. Not sure if they work.
Old 04-27-2010, 08:46 PM
Jus's Avatar
Jus Jus is offline
Rep:12
thanks bones i need to look. toothpaste didnt work. i made the mistake of sandpaperin in with wrong type of grit yikes!!
Old 04-27-2010, 08:49 PM
I push the skinny pedal
Rep:3277
You can move up in grit in stages until finally wet sanding with 1000 grit, this should give you a nice smooth finish on the headlights. It will take some time/work to do it, but you'll be happy with the result.
Kurtis
bones64's Avatar
Rep:659
Is the scratch deep and long? Like bad?
Old 04-27-2010, 08:54 PM
Jus's Avatar
Jus Jus is offline
Rep:12
man its bad, i hit with a 60grit in circular motions bout five times thinkin itll work. :/
so you think if i hit with up in grits it will come out.
i plan out tintin with vht and some clear coat
Old 04-27-2010, 09:14 PM
bones64's Avatar
Rep:659
Hitting it with different grit paper would work. Remember to do surrounding area as well. You dont want to leave a valley or something in your light. 60 to 800 or even a 1000 grit would bring it out to a good smooth finish. I have used up to 800 on my truck for the stripes and shes smooth. Im going to go to 1000 to get it good for clear coat. This isnt lights i know but im sure if you use grits in stages it should be fine. BTW if have a couple small deep scratches on my one front lights and the VHT she stays in there leaving a line. Just thought id let you know.
Old 04-27-2010, 09:17 PM
Jus's Avatar
Jus Jus is offline
Rep:12
hmm ima try the whole process out.
i have a lot to do the truck anyway. ha.
sounds like the vht would cover some of it up.
thanks again bones!
