Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 04-28-2010, 12:52 PM
Cap10crch's Avatar
Cap10crch Cap10crch is offline
Rep:18
Cap10crch is on a distinguished road
Default Speedometer Calibration
I'm hoping someone can help me, I am having the Mopar 4 inch lift put on my 2010 Ram 1500 and need to calibrate my speedometer for the 37 inch tires.
The dealership can only calibrate up to a 33 inch tire and said that I need to buy an aftermarket calibrator to do it for the 37's. The only catch is that many of the calibrators change the actual programming of the truck which voids the powertrain warranty, which would make choosing the Mopar 4 inch lift over the 6-inch Superlift which is what I really wanted, a moot point.
Hypertech has an inline speedometer calibrator but they do not make one for my truck. Are there any other products out there that calibrate the speedometer without changing the computers programming? Does anyone else have a solution to this problem?
I have to have an accurate speedometer because of where I live and where I work, there are cops EVERYWHERE.
4 inch Mopar Lift, Mopar CAI, Line-X, Flowmaster 50 Series HD, 37X12.5R20 BF Goodrich A/T
Old 04-28-2010, 01:59 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2849
with my last truck, i ran larger tires than the speedometer/odometer was calibrated to. I had asked the tire shop, Discount Tire, what the speed difference was, they have a chart in their computers software that shows the difference. Then i took that info with me, a few days later I had a friend that had a correctly calibrated vehicle follow me onto the freeway ( thats like your turnpikes & Interstates). I took the vehicle up to speed & held it at the posted speed for a couple miles, & after that, I took the info into consideration.
My odometer was off 3 miles for every 100 miles & I charge by the mile on my invoices & took that into the calculation
I have ridden my Harley without a speedometer since 1986, by just going with the flow of traffic
Old 06-15-2010, 09:29 AM
DMG698's Avatar
DMG698 DMG698 is offline
Vehicle: 2012 Dodge Ram 3500
Rep:17
DMG698 is on a distinguished road
I had the same problem with my truck but my dealer did the calibration for me and im running 37s with the 4in mopar lift on a 2010. they actually gave me the speedo calibrator. im deployed right now but i can get my friend to check what brand it is if your interested. im not sure if the warranty is different from down in the states but i live in albert, canada
Old 06-15-2010, 09:49 AM
Cap10crch's Avatar
Rep:18
Thanks, I actually went with the Hypertech Speedometer Calibrator, it is accurate, I tested it with my wife's GPS. The only pain is that I have remove the calibration each time I take it in and then put it back on so it won't be erased if they flash the truck's computer.
One thing I do know is that you have to calibrate it based on the actual tires height with the weight of the truck sitting on it, don't calibrate it for the size on the side of the tire it won't be accurate.
Old 06-16-2010, 02:18 AM
DMG698's Avatar
Rep:17
I'll have to read up on mine alittle more when i get home, thanks for the heads up. My truck is bang on right now i tested it beside my YZF-R1 with the digital speedo after i put the lift on and had it calibrated.
Old 11-13-2010, 04:07 PM
alberta1 alberta1 is offline
alberta1 is on a distinguished road
Default speedometer
do you have NAV or factory command start?
if so did you pull fuses and which ones?
thanks
Richie
Old 11-13-2010, 07:07 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
1. just use a window/dash mounted Garmin for your speed.
2. get someone to drive next to you at a few different speeds and tell you how fast you are really going. then you can just interpolate for the inbetween speeds.
Old 11-14-2010, 11:24 AM
Cap10crch's Avatar
Rep:18
thanks
Richie
I have both, looked into pulling the fuses, couldn't figure out which ones they were so said screw it and just hooked the calibrator up. It worked fine. I think they tell you to pull them so there is plenty of battery for the calibrator but the battery should have enough juice even with them plugged in. Worked for me.
calibration, speedometer
