2010 Ram Factory Trailer Brake Controller Install - Page 10 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 09-15-2010, 08:08 PM
rick980's Avatar
rick980 rick980 is offline
Vehicle: 2015 RAM Quad Cab Sport
rick980 is on a distinguished road
Originally Posted by ken99 View Post
Guys - My notes are summarized in the attached PDF file. My dealer didn't indicate this modification would cause problems, they simply insisted it could not be done. When I informed the parts dept that I had been able to make the controller work in my truck, they admitted Chrysler has issued TSB stating an adapter kit to retrofit the "B" harness would be available in late 2010. Until then I guess the "official" word is the factory controller cannot be made to work with these trucks.
Ken
So if I have the blue plug that fits into the blue plug on an 09 I am half way there? I wonder if the wires you tapped are in the harness on an 09 and if they are do they do the same thing?
Old 09-15-2010, 08:33 PM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:31
ken99 is on a distinguished road
Yes and no. The four wires in your blue plug are functionally the same four wires in found in large square grey plug on the 2010 (and I presume now the 2011). The blue plug will not fit the ITBM, so you either need to find a replacement plug from a late model Ford Superduty or run jumpers in the same fashion that I did for the second harness. It may be possable to get the 2010+ main harness from a Dodge parts counter.
I don't know. Everyone I know with a 2009 has turned me down when I ask if I can tear their dash apart and unravel the wiring harness in it. Some get rather upset over it.
Old 09-15-2010, 08:47 PM
rick980's Avatar
Originally Posted by agjames View Post
Can anyone point me in the right direction to get the bezel and controller? Canadian prices are way up there at the dealerships for stuff like this..
You close to a border? Just call and order it from a dealer with a credit card and then go pick it up . I use Southfield Jeep or Chrysler they changed their name I think haven't been in a while.
Old 09-15-2010, 09:12 PM
rick980's Avatar
Success! The photo shows the correct ITBM pin locations for the harness leads described by Netman66. I found a schematic in Dodge's body builder section labeled "Trailer Tow Module - Brake Provision - ITBM", which was a mistake. The schematic has A3 and A4 labeled backwards, which confused me.
The wires themselves are relatively easy to find, but you must remove the bundling tape wrapped around the harness where it forks for a large bundle routed towards the top of the dash. I found all three wires had small sections wrapped in tape. Removing the tape revealed bear wire. I am guessing these are the spots where the second pigtail is attached on vehicles so equiped. I have t-tapped into the lines and rebundled with tape. I cannot find a source for the small grey connector (which Yazaki part# 7283-5561-40 matches), so for now I will simply use speaker size bayonette crimp connectors on the 3 wires attaching to the controller.
Again thanks to Netman66 for his help.
Hey I have an early build 09 and after reading this about that part of the harness when I was putting t taps for my pace edwards locking tailgate I saw three or four wires that just had tape on them I thought oops a repair was made at the factory or whatever didn't check what the deal was maybe I have the ability to hook up a new trailer brake, I didn't give up on the fuel saver light and bam I got that. I could just put female spade connectors on the ends of my plug that goes into the big blue one and just plug them on separately on each connector. Then figure out the bus wires...maybe they are the same.
Old 09-15-2010, 09:28 PM
Rep:31
I would make a set of jumpers that plug into the blue connector on one end and the ITBM on the other. Over the year, I've learned it is usually best not to cut off OEM harness connectors.
Like I said in the PDF I provided with post #37, it theory it should work.
Old 09-15-2010, 09:39 PM
Angot Angot is offline
Trim Level: TRX4
Color: Mango Tango
Rep:35
Angot is on a distinguished road
I got mine installed but haven't had the chance to make it out to my trailer to make sure it works. I can however change the gain on the controller so I would venture to say something is not right with the connections or the controller itself. I will post back when I can get it hooked up to my trailer.
Old 09-15-2010, 10:03 PM
rick980's Avatar
So here is a pic of my blue plug it even names the wires so with connectors that fit the spades on, okay I am 3 wires away from a trailer brake. Can someone post where the instructions for the starscan or WII or whatever they use now.
Old 09-19-2010, 02:07 AM
Trim Level: TRX4
Color: Mango Tango
Rep:35
For the record, my controller works!
Old 09-20-2010, 09:59 PM
rick980's Avatar
The Blue part plugs into my truck and the wires are marked what they are for so I just need to put 4 spades on them and then plug the spakes into the ITBM on the side that gets the 4 and then maybe the other wires are up there in that bundle if they are I wonder if the do the same thing I suppose I could test the one for power, the others....how to know for sure. I can get trailer brake controllers everyday in the states they don't hold back like in Canada.
Old 09-20-2010, 11:03 PM
Rep:31
Yes
Did you read the PDF on this post?
http://www.ramforumz.com/showpost.ph...3&postcount=37
