Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 09-21-2010, 11:48 PM
rick980's Avatar
rick980 rick980 is offline
Vehicle: 2015 RAM Quad Cab Sport
rick980 is on a distinguished road
Originally Posted by ken99 View Post
Yes
Did you read the PDF on this post?
http://www.ramforumz.com/showpost.ph...3&postcount=37
We read it, at least I did and for one it is describing a 2010 wiring. Now we are talking about 09's yes, how can we tell if those 3 wires are the same like Ken says we could check the one for power but how do we check for what is it frequency? on the other two??? No love for us 09 owners.
Old 09-22-2010, 02:36 PM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:26
ken99 is on a distinguished road
Originally Posted by Netman66 View Post
The small connector is wired as follows;
Terminal B1, CAN C Bus (-), Circuit D51 22g WT/LB
Terminal B2, CAN C Bus (+), Circuit D52 22g WT/LG
Terminal B3, Fused Ignition Run/Start Control Output, Circuit F943 20g PK/LG
Terminal B4, Unused
You can measure the canbus lines for voltage as well. With the key on with my 2010 truck, the WT/LB line measured ~2.65 VDC. The WT/LG line measured ~2.35 VDC. I may have these backwards, but I do recall about 0.3 VDC difference between the two white canbus lines. I do remember I measured the very same voltage on the respective white leads w/ darker stripes going to the OBDC connector. I would start with measurements of those lines to give you a frame of reference.
Old 09-22-2010, 10:31 PM
garrettj79 garrettj79 is offline
Trim Level: TRX 4WD
Color: Stone White Grey Trim
garrettj79 is on a distinguished road
Old 09-22-2010, 10:40 PM
Trim Level: TRX 4WD
I have a copy of the tech essage from the dealer sitting rght in front of me. My dealer said they did not even make a 1500 with factory installed brake controller. We then went out on the lot and I showed him one on the lot with brake controller installed. He back pedaled and then looked up the notice and gave it to me. Basically the notice says.....The part is only to be used as a replacement part for a defective unit which was "factory" installed and is not to be used at dealerships to be "dealer" installed on a truck that did not already have one as it wold not work. I am not sure what to do? My dealer did not know anything about the reflashing or reprogramming either. It says there will be on available in early fall 2010 for the dealer installed option??? Any thoughts???
Old 09-25-2010, 01:19 AM
rick980's Avatar
Now we are cooking with spam! Thanks
Old 09-26-2010, 08:31 PM
rick980's Avatar
I need a bunch of 09 early build RAM owner in the Southern Ontario area that want to kick in on a trailer controller to see if we can get it to work. I got the wiring diagram etc from another forum and well I have to see for sure if the wires for the canbus are the same ones.
Old 10-01-2010, 07:10 PM
Regor's Avatar
Regor Regor is offline
Regor is on a distinguished road
Just got home, installed my controller on my 2010, 1500 ST, and I got the blinking CF ! on the controller, and the truck will not start at all.
Disconnected the larger of the two connectors and there is no error code on the Controller, the truck starts, but not sure what if all will work if/when I get ready to tow.
Anyone get that error and work around it?
Edit: Operator error - small plug was not "Snapped" in.
Old 10-01-2010, 07:39 PM
rick980's Avatar
Take it back probably a bad one. Seems to be lots of them, why I am waiting. I don't tow often usually use rental trailers with surge brakes never had an issue. Never tried on hilly roads.
Old 10-01-2010, 11:27 PM
Rep:26
So does the controller work properly when both pigtails are installed correctly?
Just got home, installed my controller on my 2010, 1500 ST...
I'm still trying to decipher why some 1500 trucks have both connectors and others only have one. I thought it was likely trim related, but your ST disproves that notion.
Old 10-02-2010, 07:29 AM
RockStar RockStar is offline
RockStar is on a distinguished road
Ya strange your ST has it and my 2010 SLT with tow package does not...
Has anyone found a dealer doing the EVIC flashing? Not only would I like to get my EVIC flashed for the brake controller but i also added the mirrors with the signals. Id imagine its just as simple as enabling them with the starscan tool? Ive seen videos on youtube for disabling DRLs so should be option to enable trailer brake there and enable mirror lights...
Wish aftermarket company would come out with a EVIC programmer so can enable your own options and shit as your purchase them. Should be a way to enable the 0-60 timer too like in the challanger.
