Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 10-04-2011, 01:58 AM
msjgrizz msjgrizz is offline
Vehicle: 2012 Dodge Ram
msjgrizz is on a distinguished road
Originally Posted by ken99 View Post
The current part number for the Integrated Trailer Brake Module (ITBM) is 56029431AH. Unless Dodge has redesigned the integrated brake controller for 2012, this part should be correct. A bezel is also needed to match the dash color and part numbers vary by color choice. Any Dodge dealer can order these parts for you or you can go to one of many internet parts sites.
Thanks for the info Ken! Gave the dealer that part number and they said it was for up to 2011. But they also said that they have not been updated fully on the parts list for the 2012's.
Guess I will give them another month to get caught up. I just hope the wires are there to do the plug and play install.
Old 10-07-2011, 09:25 PM
gshelton777 gshelton777 is offline
Vehicle: 2011 Ram 1500 Sport 4x4
gshelton777 is on a distinguished road
Just added the OEM brake controller to my 2011 1500. Piece of cake. I suggest using a nut driver with a 7mm hex driver bit to loosen and reinstall the two screws holding the under-steering wheel panel. I believe the three screws I used were number 8 x 1/2" sheet metal screws.
Regards, Glenn
Old 10-09-2011, 10:49 AM
I also added the OEM Brake controller. Just really surprised how easy it was to install.
I installed mine in the dealer parking lot so I could be there to get them to flash it if it needed it. It did not need flashing.
A big thanks to all that took the time to post info about the OEM Brake controller!!!
Old 10-10-2011, 04:21 PM
dmathewswpd51 dmathewswpd51 is offline
Trim Level: TRX
dmathewswpd51 is on a distinguished road
I have a 2010 Ram 1500 with the Factory Installed Trailer brake system. About a week ago I got a message to "service trailer brake system". Have pulled a trailer twice with no problems, truck just turned over 10,000 miles. The second time was after the service message came on. Any suggestions on how to clear this warning. System appears to be working as required. I've pulled the battery off for 1/2 an hour and put it back but indicator still on.
Thanks
Old 10-18-2011, 02:49 AM
Bluebee Bluebee is offline
Bluebee is on a distinguished road
Hey what's a reputable website to order the trailer brake and bezel parts? I've tried my stealership but they will only sell me the full kit at twice the price.....please pm if u know of a good site that carries the part, I can't seem to find one...I must be internet challenged.
Old 10-18-2011, 07:03 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
i got mine earlier this year from mopar-wholesale.com they had the controll on sale for about $95 and the bezel for about $5 it came from a dealer in tampa
Old 10-21-2011, 01:00 PM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:26
ken99 is on a distinguished road
I've been trying to determine what triggers this message. I found only one other instance on the Internet, and it was related to a wiring problem (a short?) with the 7 pin connector on the back of the truck. I would try using the same process to delete this message from the EVIC as the "oil needs changing" message. Turn the key to the on position (but do not start) and press the accelerator pedal three times. May/may not work, but it certainly would do no harm.
It also might have been better to submit this thread as a new post in one of the general discussion sections since I think more folks would have seen it. You might consider doing that if my suggestions don't work out.
Old 10-24-2011, 04:14 PM
Ironsides Ironsides is offline
Vehicle: 2009 Dodge Ram 1500 CC 4X4
Trim Level: SLT Big Horn
Rep:44
Ironsides is on a distinguished road
Ken or Netman,
I wired an ITBC into my '09 Ram 1500 over the weekend. I don't have a trailer with electric brakes to test the controller on right now. I might have access to one later in the week, but for right now, I have no real way of testing the controller. When I start up my truck, all the lights on the controller come on for a few seconds, and then they all go off. After that, the controller doesn't display anything. I found this in the '10-'11 User Manual
"If no electrical connection is detected after the ignition is turned on, pressing the GAIN adjustment button or sliding the manual brake control lever will display the GAIN setting for 10 seconds and the 'Trailer Brake Status Indicator Light' will not be displayed."
When I press either of the gain adjustment buttons, or slide the manual lever, nothing happens. Is this typical for a truck that hasn't been programmed for the ITBC, and doesn't have a trailer connected, or is something not right? I have what I think is the latest controller, 56029431AH. Thanks.
Old 10-24-2011, 08:50 PM
Rep:44
Small update: When the lights are on, the controller gain displays like the User Manual describes. I'm not sure if the controller shuts off when the lights are off, or if the display just turns off. I'll have to test it with an unloaded trailer later this week.
Old 10-26-2011, 11:25 PM
Rep:26
When the ignition is turned on, the ITBM display will light up briefly and then go black. Pressing one of the gain control buttons or pressing on the brake over-ride level will display the present gain setting. With lights on, the +/- buttons should be lit. This is on my truck that I've never had the EVIC reprogrammed for the controller. Yes, connecting a trailer with electric brakes is the ultimate test.
