Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 07-18-2010, 10:04 PM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
Yes - for a 2010 model.
The EVIC does not need to be flashed for it to work as a normal brake controller, however, once connected to the CANBUS it will log an error to the computer (no light) which may be an issue should there ever be something else wrong that requires them to read any codes to troubleshoot.
But it will work fine.
Old 07-20-2010, 08:09 PM
mildtowild's Avatar
mildtowild mildtowild is offline
Vehicle: 2010 Ram
Trim Level: Sport crew cab
mildtowild is on a distinguished road
Originally Posted by HDclassic View Post
I went to my local dealer and they told me that the brake controller will not work in the Ram 1500. From your write up they are wrong. I guess I should just install it and prove them wrong. Will the controller work without the EVIC being flashed.
They told me the same thing, something about there is a bulletin out that they don't work. But they still booked me in to flash the computer. there are no controller available here in BC, all on back order so i had to get mine from the States. installing it was super easy.
Old 07-25-2010, 07:34 PM
Shedhead Shedhead is offline
Vehicle: 2010 Dodge Ram Crew Cab 4x4
Color: Inferno Red
Shedhead is on a distinguished road
I phoned various dealers here to get one. The answers ranged from:
- we don't fit the factory one, we use a different one
- you can only have one fitted if you order one with your truck
- been on back order for months
- we don't have any but this dealer does.
I went with the last response, called the dealer and picked one up next day.
Fitted it in a few minutes, took the trailer out today, it worked fine.
It doesn't show up on the EVIC as the truck hasn't been updated but at the moment that's not a great concern to me.
Thanks for the original post Netman66 it made the install easy.
Old 07-25-2010, 08:55 PM
Rep:82
You're welcome, glad it was useful!
Old 07-29-2010, 02:07 PM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:26
ken99 is on a distinguished road
Great post. My new 2010 Ram 1500 SLT Crew was suppose to have both connectors installed with the "trailer tow wiring with 4-pin connector" option, but is missing the second small grey connector. No, my dealer cannot explain why. Would you have a clear photo of the back of the small grey harness connector? I've figured out which wires to run, but haven't figured out how they map to the pins on the connector. Again great job documenting your efforts.
Ken
Old 07-29-2010, 02:45 PM
Rep:82
Pinouts are as follows:
The large connector is wired as follows;
Terminal A1, Ground
Terminal A2, Brake Lamp Switch Output
Terminal A3 12 volt Positive
Terminal A4, Trailer Tow Brake Wire
The small connector is wired as follows;
Terminal B1, CAN C Bus (-), Circuit D51 22g WT/LB
Terminal B2, CAN C Bus (+), Circuit D52 22g WT/LG
Terminal B3, Fused Ignition Run/Start Control Output, Circuit F943 20g PK/LG
Terminal B4, Unused
Old 07-29-2010, 10:47 PM
Rep:26
Terminal B4, Unused
Thank you for your help. Since I don't care if I have the canbus related features installed, I suspect I only need to wire the pink/light green wire to B3.
Old 07-29-2010, 10:49 PM
Rep:82
My pleasure. I hope it helped.
Old 07-31-2010, 01:43 PM
Rep:26
Netman66 - Can you confirm that I have the canbus or B connector correctly mapped? I was able to find a schematic on the net mapping the main module connector (aka, A connector), but nothing for the small one. I'm using the same logic on the B connector as the A. Since the pink/lg wire has some amperage, I fear connecting it wrong could be disasterous.
Ken
Last edited by ken99; 07-31-2010 at 11:29 PM. Reason: ken99 can't spell worth squat.
Old 08-01-2010, 06:14 PM
Rep:26
Success! The photo shows the correct ITBM pin locations for the harness leads described by Netman66. I found a schematic in Dodge's body builder section labeled "Trailer Tow Module - Brake Provision - ITBM", which was a mistake. The schematic has A3 and A4 labeled backwards, which confused me.
The wires themselves are relatively easy to find, but you must remove the bundling tape wrapped around the harness where it forks for a large bundle routed towards the top of the dash. I found all three wires had small sections wrapped in tape. Removing the tape revealed bear wire. I am guessing these are the spots where the second pigtail is attached on vehicles so equiped. I have t-tapped into the lines and rebundled with tape. I cannot find a source for the small grey connector (which Yazaki part# 7283-5561-40 matches), so for now I will simply use speaker size bayonette crimp connectors on the 3 wires attaching to the controller.
Again thanks to Netman66 for his help.
