Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 08-20-2010, 07:43 PM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:26
ken99 is on a distinguished road
Originally Posted by tlw54 View Post
I have a question, looking to buy a 2010 Laramie this weekend, but it doesn't have the controller. In fact when I looked at the hitch and behind it, I didn't even see a wiring harness. If the truck was ordered without the trailer brake controller, would it have been built and shipped without the harness?
If the truck is wired, the trailer connectors will be just to the left of the rear license plate.
Old 08-20-2010, 07:45 PM
hobbsdodge hobbsdodge is offline
Vehicle: 2010 quadcab 1500 4x4
hobbsdodge is on a distinguished road
Check next to the license plate, left side, you will see 2 black doors, 4 pin and 7 pin are there.
Old 08-20-2010, 09:33 PM
Talayoe's Avatar
Talayoe Talayoe is offline
Color: Blue
Talayoe is on a distinguished road
I hate being a pest but did anyone see my post at the end of page 6? Page 7 started almost immediatly after.
Old 08-21-2010, 08:00 AM
Talayoe's Avatar
Color: Blue
After a fair bit of research it turns out the CF mean Controller Fault. Says in the owners manual to 'See licensed technician'... Had me bothered all night that stupid thing was busted.
When I got to work this morning, I reached under the dash and it turned out the small wire harness wasnt pushed in to 'snap' in place. Heard the click, turned the key back on and PERFECT! I am happy!
Old 08-21-2010, 12:48 PM
Rep:26
Originally Posted by Talayoe View Post
Second, was anyone else who did this disappointed in the front cover panel screw holes under the steering wheel? No washers or nothing on those little screws and the holes are SEVERLY messed up on mine. I was able to put it back on nice and tight but I was scared the plastic would rip through.... Anyone else see/have this?
Yes, my truck had these screws as well. I simply went down to O'Reilly's had bought a couple of black body screws with larger heads. Even had torx heads to match the screw heads holding the controller in place. More secure and looks OEM. You can likely find similar screws at any hardware or automotive store.
Old 08-24-2010, 11:49 AM
RockStar RockStar is offline
RockStar is on a distinguished road
I just got a 2010 Ram SLT about a week ago. Has hitch, 4 pin and 7 pin connectors. I would really like the factory trailer brake as I do a lot of towing.
I looked up under the dash and I only see one empty connector. Well actually I see two. One is male the other is female. One has 4 wires coming off it while the other has 5 pins inside of it with 5 wires going to the connector. The 5 pin one is fixed underneath the dash. I'll try to get a picture later to explain it further.
*EDIT* forgot to mention mine is a 1500.
Thanks,
Richard
Old 08-24-2010, 12:51 PM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
I originally saw 1 connector. The other one was taped up quite well and until I peeled the tape off it wasn't apparent. My picture shows both after I unwrapped a little of it.
It is possible you only have one connector. My understanding is that unless you have the tow package it's not there. I could be wrong though.
Old 08-24-2010, 02:42 PM
I do have the tow package (transcooler hitch, 7 pin and 4 pin).
The end might be there. I will look a little more after work. Are they both male connectors?
Old 08-24-2010, 02:55 PM
Rep:82
The connectors should be female. The controller has male connectors in each socket.
Old 08-24-2010, 04:50 PM
So I did some digging... and cannot find the wiring. Guess its not there but on my build sheet I do have tow package with heavy duty coolers. I checked the 7 way on the back of the truck and there is in fact 7 wires coming from the plug going towards the cab.
Sorry for the shitty cell phone pics, but they give you the idea of what Im working with. I have one unused female connector and one unused male connector.
