Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 08-29-2010, 10:04 AM
mricig mricig is offline
Vehicle: 2010 Dodge Ram Crew Cab 4x4
Color: Blue
mricig is on a distinguished road
Originally Posted by ken99 View Post
Mike - Is there a difference in the two codes as far as application is concerned?
I do not think so. When they go to the computer, they select it from a list of options anyways. Some forums say its XHC, some say XHCA, but for sure the XHC is the important part. The A may be a new revision, because this application used to not work at all, regardless of flash. Somehow Dodge fixed this issue.
Mike
Old 08-31-2010, 08:40 AM
md99ram md99ram is offline
Vehicle: 2010 Ram 1500 Hemi
Trim Level: laramie
Color: two tone Auston Tan
md99ram is on a distinguished road
Question NO Gain
I bought the control module from the dealer installed as instructed in earlier threads. (plugged in the 2 gray plug's) hoohed it up to my trailer it apears to work but no brake (when the the truck is slowing down the #'s will increase and then decrease as the truck slows) The Gain is set at -00- and will not let me increase the gain and with no gain no brakes. "correct?"
Please help me find the solution for this problem.
Thanks
Old 09-05-2010, 11:47 PM
Color: Blue
You may have a bad brake controller module. I was able to adjust the gain without the trailer connected and without the dashboard even programmed. You may want to return it and get another one, as something just doesn't sound right.
Mike
Old 09-06-2010, 09:43 AM
agjames agjames is offline
Vehicle: 2010 , crew cab, 1500
Color: inferno red
agjames is on a distinguished road
Can anyone point me in the right direction to get the bezel and controller? Canadian prices are way up there at the dealerships for stuff like this..
Old 09-10-2010, 11:31 PM
Angot Angot is offline
Trim Level: TRX4
Color: Mango Tango
Rep:35
Angot is on a distinguished road
I went to my dealership to order one today and they gave me this tech tip. They couldn't provide me with a date the kit would come out. I went ahead and ordered it, I have faith based on this thread it will work.
Old 09-13-2010, 09:45 PM
Trim Level: laramie
hello A/ngot,
I did this exactly as described, got the dealer to flash the computer and it doesn't work there is no gain adjustment at all. can you please let me know how this turns out for you
Old 09-13-2010, 10:35 PM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:26
ken99 is on a distinguished road
Originally Posted by md99ram View Post
hello A/ngot,
Can I ask which buttons you are using to adjust gain? Arrow buttons on the steering wheel or the +/- buttons on the controller itself?
Old 09-14-2010, 04:33 PM
Trim Level: laramie
Default trailer brake dont work
Can some one help me? I have a 2010 Ram 1500 I went through all of the installation instructions as posted in the earlier threads for the trailer brake controller. The dealer flashed the computer. Everything seems to work visually, Such as the on dash display and the control module it self seems to indicate that everything is working fine. The problem is that there is still no brake. The gain on the controller is showing 0.0 and will not increase. I'm not sure but I think that there is something wrong with the controller it self. The dealer can't or won't test it for me. Is there any way that I can test this controller myself. If any one know anything Please let me know.
Old 09-14-2010, 04:36 PM
Trim Level: laramie
I tried the controller +/- first then tried the steering +/- controls and still nothing.
Old 09-14-2010, 08:34 PM
Rep:26
If the controller doesn't respond to the +/- gain control buttons, I would assume something is wrong with it. It should be warrentied. I'd return it to the parts counter for an exchange.
Actually, I would first un- and then re-install the controller to make sure that both harness plugs and each wire in both plugs are securely seated in the controller. This could be a minor wiring glitch caused by a bent pin or broken wire. You can also use a multimeter to check voltage and grounds of the leads as described in earlier posts of this thread. Then take it back if you can't make it work.
