Old 04-29-2010, 04:27 PM
PmkColorado PmkColorado is offline
PmkColorado is on a distinguished road
Default '97 poor brake performance...help
two feet on the pedal and cannot make it skid...what to check? Front pads are at 80%, rear drums not sure; fluid ok. Mechanic said it is normal...no way. Note that I am helping my sons friend (16) who has already rear ended two other cars...truck will not stop.
Thanks
Old 04-29-2010, 04:36 PM
Resident Technician
Rep:1915
What does the pedal feel like? High and hard (get your mind out of the gutter Paris) or low and spongy? A hard pedal indicated a bad brake booster and a low pedal could indicate a leak, air in the system, bad rubber lines, caliper or cylinder problems, rear drums misadjusted or a bad master cylinder.
Old 04-29-2010, 04:51 PM
high and hard...no matter how hard you push the pedal...
Old 05-01-2010, 02:37 PM
Resident Technician
Rep:1915
Definately a bad brake booster or you've lost the vacuum source to it.
Old 05-01-2010, 04:05 PM
Rep:1625
Welcome to the forum PmkColorado! We're glad to have you here!
