Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 04-29-2010, 10:13 PM
castorriver castorriver is offline
castorriver is on a distinguished road
Default Washed engine now truck is dead
Hello all this is my first post. I have a 98 dodge ram 1500 with the v8. I washed the engine the other day and it ran rough for a few days especially when idling but today it died and won't start at all. it was running good while driving but died when idling but I could restart it.
Now none of the interior lights work and everything is dead. I put it on the battery charger for a while thinking it was a dead battery but it's still dead. When I turn the key I get nothing but silence. I opened up the box next to the battery where the black and red battery wires go into and it's bone dry. The big fuse between the black and red wires looks good. I've left the hood up all day hoping to dry it out. Any advice?
Old 04-29-2010, 11:10 PM
iRESQu iRESQu is offline
Rep:2217
First of all, welcome aboard. I am not as knowledgable as most on here but I was always taught to becareful of the distributor/plugs, that kind of stuff. Sounds like something electrical got wet. All fuses are good? All wires are still protective coated? I am totally taking a stab in the dark, but if you stick around someone with far more vast knowledge will chime in. Best of luck.
Old 04-29-2010, 11:12 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
did you just spray with out covering anything?
Old 04-29-2010, 11:22 PM
I push the skinny pedal
Rep:3308
Welcome to the Z! You could have soaked lots of different things; the alternator, the starter, the fuse box, or even the coil/distributor. So you've swapped out for a new batter or had the one you have load tested?
Kurtis
Old 04-29-2010, 11:33 PM
Rep:1625
Welcome to the forum! Glad to have you here!
Old 04-29-2010, 11:49 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Welcome to the forum. I would check all that Kurtis mentioned. Gotta be careful with water under there.
Old 04-30-2010, 12:31 AM
No I didn't cover anything before washing it, I know now that wasn't the greatest idea. I do have power to the fuse box on the fender next to the battery. I checked it using an ammeter. But still nothing. I don't know why it ran halfway decent for a few days then stopped altogether.
Old 04-30-2010, 12:34 AM
Thanks for the advice. I think I'll open the distributor tomorrow and check the plug wires. The battery is the same one but I put it on the charger. I bought the truck from a friend a few weeks ago and I noticed the battery is 5 yrs old... That would explain not starting b ut why would it die out at idle?? Thanks doug
Old 04-30-2010, 12:40 AM
Rep:3308
If the alternator's not putting out enough/any juice, then it's running mostly on the battery, which can only put out so many amps, not the 130(? on your gen) that the alt puts out to run the coil continuously. Having a bad alt will also kill an old battery, so this might be the culprit.
Kurtis
