Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 02-25-2011, 03:35 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
Another idea is to mount long shanked J-hooks to the each side of your trucks frame so the hook sits below the bumper and any dam you may have. I actually do have factory tow hooks on my trucks but since a snow plow is mounted most of the winter, the hooks are useless (when the plow is on the ground or raised, the hooks are blocked).
Since the hook on the J is below the air dam, I can use it when the plow is mounted (I have used it serveral times this winter given all the snow in New England). The tow ropes and chains I use with the J have never touched any part of the truck given the hooks positon in relation to the front of the truck. I will snap a picture and show you what I mean. I have mounted such hooks in the rear as well. If I recall, my 2500s had pre-drilled holes on the front frame rails. I drilled another hole on each side such that the J shank was firmly mounted on the frame (had to drill a hole in the shank of the J as well).
