Old 04-30-2010, 12:40 PM
chad47 chad47 is offline
chad47 is on a distinguished road
Default tranny 2003 ram
my ram 1500 4.7 going down highway running about 1500rpms shifts in and out of gear real hard i changed filters
Old 04-30-2010, 12:43 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
hello and welcome, i am sorry i cant help you but i am sure someone who can will be along soon
Old 04-30-2010, 01:18 PM
Rep:1625
Welcome to the forum! Glad to have you here! Hang in there, help should be on the way shortly
Old 04-30-2010, 01:26 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Welcome to the forum! Good luck with your truck.
Old 04-30-2010, 04:05 PM
dropt02's Avatar
dropt02 dropt02 is offline
Vehicle: 2002 Dodge Ram
Trim Level: st
Rep:23
dropt02 is on a distinguished road
Send a message via Yahoo to dropt02
mines sitll does this but i kno why mine does. have u ever swapped in a diff tranny or has anyone before u who had the truck swapped the trans, bc if so they say ur supposed to get it reprogrammed
Old 05-01-2010, 05:16 AM
fuzzy fuzzy is offline
Vehicle: 2003 Dodge Ram
Color: Patriot Blue and silver
fuzzy is on a distinguished road
Default Hi I had the same problem
I was keeping it in over drive way too much as well as when i bought it the Transfer case was cracked so that was causinf some real hairy issues. as for the transmissing I was getting a bucking going from a lower gear to a higher gear. it was like it was stuck in over drive and could not downshift. I tried somehting that I usually dont do. I bought some Lucas automatic tranny lube I sucked out a quart then put this stuff in. the next step was the tranny shop for me. I took it for a test drive and after about 3 miles it acted like a whole new transmission. It was shifting properly down shifting properly ect.. So you might want to try a can of that. I dont know if it will help the problem but it made my problem go away. Like I said U usually dont try liquid fix in a can but I figured for the 11 dollars it would not hurt befpre spending at the minimum 1400. for a rebuild. I hope this helps
Fuzz
Old 05-21-2010, 11:33 PM
dropt02's Avatar
Trim Level: st
Rep:23
forgot to mention that i put lucas tranny stuff in ever change, do it in ever oil change, the rear and everything
