Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 05-04-2010, 11:50 AM
Carbonless Carbonless is offline
Vehicle: 2010 Ram 1500 5.7 CC 4x4
Carbonless is on a distinguished road
No leveling is required after the install. It's not difficult, but be careful when removing the grill. After the 4 bolts on top of the grill there are plastic spring clips at the bottom that need to be released and then 2 friction pins to pull the grill out towards the front of the truck. If you just tug on the grill then these may break Dont forget the single metallic screw inside the headlight access panel or you'll be fumbling around for awhile.
Pull up on the plastic radiator cover (all friction pins so pull straight up)
4 screws on top of radiator/ engine bay to release grill - plus 4 spring clips and 2 friction pins on bottom (pull directly towards front)
2 screws in front of headlight assembly
1 screw and the headlight release lever on inside of wheel wheel (push directly up on lever to release ball bearing lock)
I mounted the ballasts on outside of frame inside the headlight assembly cavity
Old 05-04-2010, 02:02 PM
Subydude09's Avatar
Subydude09 Subydude09 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4x4 Crew
Rep:50
Subydude09 will become famous soon enough
Cool, thanks for the quick write up! Sounds like it's gonna be a little bit of fun. My old F-150, all I had to do was open the hinged rad cover under the hood, and the light bulbs were right there, a 1/4 turn and they were out!
*Tow Hooks *LineX *Truxedo Bed Cover *SS Step Bars *HID's *Flowmaster 40 *35% Tint *Nightshades
Old 05-04-2010, 04:33 PM
glamontagne's Avatar
glamontagne glamontagne is offline
Vehicle: 2009 Dodge Ram Crew
Rep:55
glamontagne will become famous soon enough
I was able to remove my headlight assemblies without removing the grill. I used a 10 inch extension for my ratchet to get to the bottom headlight screw.
Gary--2009 Black Ram Crew 5.7 Truck Champ Stainless tube steps,Tekstyle Tonneau Cover, LED Interior, LED License Plate Lights, LED Reverse Lights, LED Cargos, 5900k Headlights and Fogs.
Old 05-04-2010, 10:21 PM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
Could it be that the two different removal methods talked about here are because of different headlight configurations? My truck has the quad bulb configuration and I didn't have to remove the grill. Two screws under the hood on each light housing. One on top inside corner with the head pointing forward and one down low on the inside edge behind the grill with the head up that you access with a long extension on a ratchet. The hardest part was the freaking slide lock thingy you did by feel unless you remove the wheel so you can see (or have a very tiny head and shoulders so you can squeeze in there). It's just a thought but is the dual headlight housing mounted differently?
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
Old 09-01-2010, 02:20 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
i remove the grille its easier that way.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 12-31-2010, 02:52 PM
mweinbender mweinbender is offline
Vehicle: 2011 Ram 1500 Crew 4x4
mweinbender is on a distinguished road
...or a video. What a pain in the ass!
Old 12-31-2010, 10:49 PM
09 RT RAM's Avatar
09 RT RAM 09 RT RAM is offline
Rep:39
09 RT RAM is on a distinguished road
The dealer here removes the grill.
WARNING -- TUCK BLUE 3M PAINTERS TAPE ALONG THE ENTIRE TOP OF THE BUMPER UNDERNEATH THE ENTIRE PERIMETER OF THE BOTTOM OF GRILL TO AVOID ABRASION WHEN REMOVING SAID GRILL OR YOU MIGHT VERY WELL SCRATCH THE BUMPER. TUCK IT GOOD. BE CAREFUL.
YES, I AM YELLIN'.......
Old 12-31-2010, 11:04 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
these are a pain in the ass to do if you dont know how to do it
Old 12-31-2010, 11:45 PM
Minarets Minarets is offline
Vehicle: Pontiac G8GT
Minarets is on a distinguished road
And I don't so I am hesitant as he'll to do the bulbs
Old 01-01-2011, 11:08 AM
09 RT RAM's Avatar
Rep:39
Talking
yes, but easy once you figure it out...... the part where you open the small door in the fenderwell to get to the retainer you must slide down to unretain is a damned trip. Dodge has closed the gaps tight on these trucks. The CD is low for a pickup. A top design engineer for Mercedes is responsible for some of what you see. So it is not an easy task to remove these lights until you get the hang of it.
