Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Washing & Waxing
Washing & Waxing Washing and Waxing your Dodge Ram! Talk about it here!
Old 05-01-2010, 12:28 AM
jayhkr's Avatar
jayhkr jayhkr is offline
Vehicle: 2006 Dodge Ram SLT 4x4
Color: Atlantic Pearl Blue Metallic
Rep:75
jayhkr will become famous soon enough
Send a message via ICQ to jayhkr
Default Power Washer
Does anyone use a power washer to washer their truck? I just bought one to clean the deck and siding and it has two separate solution tanks, and I was thinking of using one to keep the truck wash in. I normally use Megs Gold class, however it seems to be a little thick and doesn't want to go through it very well. Anyone have any suggestions with this application? Any help is appreciated! Thank you!
Old 05-01-2010, 12:39 AM
ScatPak07's Avatar
Rep:970
I would just use the power washer to wash it off and use the good old scrubbing way with the soap. At least if you use a sponge to soap the truck down you are wiping all the dirt and everything off. Usually when you use soap out of a power washer it does not really get everything off. When you dry the truck thats when it all come off.
I do not know how to allow the soap to flow through the power washer sorry man
Old 05-01-2010, 04:04 AM
Rep:4072
Gotta agree with Scat, better to use the power washer for rinsing before/after and the like, but I prefer the old fashioned elbow grease haha when it comes to washing. I definitely like the power washers for getting the soap off, does a great job at that, it's just that most of those are designed for solutions more along the lines of bleach or mean green, something like that, not something thicker like car soap.
Old 05-01-2010, 08:16 AM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
Ye I have a power washer just bought it month or so back but I have never been a fan of them. I needed it to wash the drive down remove the dreaded moss As a person who has painted the inside and outside of houses [ for many! many! years] the only way you can break up the grease and dirt which is basically the same as car washing is to use a recommended detergent and hand soap the object a truck in this case. It is the only way to loosen dirt & grime . I would certainly only use the least powerful jet nozzle to loosen and remove mud etc before soaping up and removing the soap after sudsing up, as with the power they have they can certainly do a lot of damage. Strangely, though you defiantly need to hand soap the truck, I am not sure if the power washing will shorten the life of a good wax finish as apposed to just the hose, I am sure wiser heads will let us know.
Old 05-01-2010, 11:18 AM
jayhkr's Avatar
Rep:75
Thanks guys! I am a fan of hand washing, don't get me wrong, I just thought if there was "secret" solution out there for it I would give it a go. Belive me, I understand the importance of hand washing as it allows you to get personable with your truck and you can really get into all those hard to reach areas. Since I don't go mudding a whole lot I'll stick with the foam gun and hand mitt!
Old 05-02-2010, 05:35 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Ya i have used a pressure washer to rinse my truck! but always use hand mits to wash the truck to get everything off!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 05-02-2010, 05:38 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
hand wash it and rinse it off with the washer but be careful i took the paint off my last truck LOL
Old 05-02-2010, 05:43 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I use a power washer. Put the soap on through it too, then use a mit to scrub. Then rinse again with power washer. I think its 40 degree nozel that I use, so its not that bad on the truck. I have used on either at home or when I worked at the dealerships.
They can rip skin off, and I have done it.
Old 05-07-2010, 12:25 AM
Smitty's Avatar
Smitty Smitty is offline
Vehicle: 2009 Dodge Ram 1500 4 x 4
Smitty is on a distinguished road
Are you using a low pressure nozzle when trying to apply the soap? Most pressure washers use a low pressure soap/chemical injection nozzle and will not operate at maximum operating pressure. I have never had any issues when running all types of car wash soap through the chemical injection on my pressure washer.
Old 05-20-2010, 02:32 AM
hockeyplaya13's Avatar
hockeyplaya13 hockeyplaya13 is offline
Vehicle: 2002 1500 Quad Cab SLT
Color: Atlantic Blue
Rep:22
hockeyplaya13 is on a distinguished road
Pretty sure you can't get the soap to go through the pressure washer. BUT you can get a foam cannon/foam lance that attaches to the end. Granted, this doesn't eliminate the need to hand wash it, but it does help loosen the dirt a bit and reduce the chances of marring/swirling. I use a foam gun with my regular hose, and my usual process is foam it down at a more concentrated solution, let it soak for a few minutes, spray it off, and then foam it down at a lower solution and go to town with the two bucket wash method.
Pro's:
-Helps minimize the chance of marring/swirling
-It's a ton of fun and very cool
Con's:
-Cost ($50-$100)
-Use a bit more car shampoo than usual
