need help with heating and ac problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 05-01-2010, 02:00 AM
pattoves777
Default need help with heating and ac problem
hi i have an issue with my heater and a/c, seems that my heater stays on even though my a/c is running. i am guesing that it could be the climite control switch anyone come acorss this problem, your help would be apresheated. thanks pat
sorry it is a 2000 dodge ram.
Old 05-02-2010, 07:39 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Most likely your control switch has gotten disconnected or is bad.
www.beatcraigslist.com - for posting dangers & secrets
Old 06-19-2010, 11:03 AM
krb krb is offline
Gender: Not Specified
krb is on a distinguished road
My '01 2500 was doing the same thing.
I removed the dash only to find that a $10 blend door coupling broke with the door opened on the hot side air.
The plastic coupling is mounted between the control motor and door.The motor and coupling can not be removed without pulling the dash.
I will be taking some pics.
BTW,I think I spent about $160 for the switch thinking that it was the problem.
Old 06-19-2010, 11:38 AM
If it's not switching from heat to A/C then I'd suspect the switch too.
If it doesn't switch from heat/floor vent to heat/dash vent or heat/defrost vent the I'd suspect the blend door.
Old 06-19-2010, 11:43 AM
krb krb is offline
Mine would switch but the door was stuck on the heat side.
