Old 05-01-2010, 07:34 PM
joseph7195's Avatar
joseph7195 joseph7195 is offline
Vehicle: 2002 Dodge Ram Quad Cab
Trim Level: basic, but adding on
Rep:26
joseph7195 is on a distinguished road
Question Leaky Head Gasket? Only reason for milky fluid in Oil?
I was recently coming home and the lower radiator hose came off. I was able to stop the engine before it overheated. I put the hose back on and filled up with coolant. When I tried too crank it, the engine sputtered for a couple seconds and then I turned it back off. Then I tried again and it cranked up with hesitation. I checked the oil and there was a milky colored fluid in it. I checked the coolant again and I am not losing any coolant anymore. Now the milky fluid is gone from the oil. I honestly don't know what is going on. I haven't driven the truck, but I have cranked it. I really don't want to change the head gasket if I don't have to. Is there anything else that's "simple" that it could be? Thanks in advance!!!
2010 USACI World Finals Champion, 2nd Place Port Wars. 168dbs
Old 05-01-2010, 08:39 PM
Rep:1625
Welcome to the forum! Glad to have you here! Sorry, I don't have an answer for you, but I'm sure one of our other members will, hang in there
Old 05-01-2010, 08:48 PM
eddie's Avatar
eddie eddie is offline
Vehicle: 2004 dodge ram
Color: green
Rep:17
eddie is on a distinguished road
it could be the intake gasket i wouldnt run that that motor untill u change the oil tho
Old 05-01-2010, 09:28 PM
joseph7195's Avatar
Rep:26
I don't believe the 4.7 has coolant running through the intake. I am gonna change the oil tomorrow morning. and then I am gonna see if the fluid is back. Oh gosh i hope i don't have to change the head gaskets.
Old 05-01-2010, 10:06 PM
silvermist's Avatar
silvermist silvermist is offline
Vehicle: 08 dodge ram quad cab 1500 4x4
Trim Level: sport
Color: sunburst orange
Rep:37
silvermist is on a distinguished road
pull the plugs and check to see if you have coolent in the cylinders as i beieve if your head gasket goes it will burn coolent. i think coolent in the oil is a crack in the block. but i'm not 100%
Old 05-01-2010, 10:34 PM
joseph7195's Avatar
Rep:26
I was wondering if the loss in pressure could have done the damage. because the engine didnt have time to overheat. I turned the engine off immediatly when the lower radiator hose came off. so the engine didnt overheat. I really appreciate all the help I have gotten from yall guys. it's truely an honor
Old 05-02-2010, 12:07 AM
joseph7195's Avatar
Rep:26
I am hoping a veteran see's my trouble and gives me some insight on a quick fix, or helps me with the total overhaul of my engine, I hope... I really love my Dodge!!!!
Old 05-02-2010, 08:40 AM
Glad you joined us and welcome to the Z for Rams from Baltimore . Place a preferably glass container under the oil pan drain plug . Pull the plug and capture the first couple seconds of oil in the glass container . Let it sit and see if it seperates . Water is heavier than oil . That will help tell you if you have water in the oil pan . Do you have any pictures of your truck ? Have you done any mods or have plans for mods in the future ? Any of your friends have Rams ? Tell them about us . We would love to have them . You will find this site is full of a lot of talented people . So if theres any question that you need answered , just shoot away . Talk to ya soon . Tom
Old 05-02-2010, 10:37 AM
I push the skinny pedal
Rep:3277
Welcome to the Z! Tom had a good idea, check if there's any water in the system, that could cause a milky look to the oil. I'd still pull the plugs to see if any of them are gummed up, this could be causing the spluttering issue. if there's anything on the plugs then you had something into the cyclinder, and then I'd be looking at the head gasket.
Kurtis
Old 05-02-2010, 11:01 AM
300 Addict's Avatar
300 Addict 300 Addict is offline
Vehicle: Chrysler 300
Trim Level: Touring
Color: Satin Jade Metallic
Rep:317
300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough
Welcome to RamForumZ, from Barrie, Ontario, Canada! Glad to have you join the family here! Enjoy the site!
coolant, head gasket, milky, oil, smell
