Old 05-03-2010, 01:52 PM
TwinTurbo392 TwinTurbo392 is offline
TwinTurbo392 is on a distinguished road
Yeah probably ones with as little of dust as possible...
Kind of off that note... does anyone know if the 2009+ fuel tanks are metal inside with a plastic shell, or are they just molded plastic now? Thanks!
Old 05-03-2010, 10:13 PM
turbo392's Avatar
turbo392 turbo392 is offline
Gender: Not Specified
turbo392 is on a distinguished road
Good luck with the build and keep us updated. I am not aware of any block failures from boost and several builds have been 1000+ hp at the crank. There is a truck that will be racing that summer that will likely be the highest output from any new gen Hemi, but with a partial block fill for strength. (using a FR2 blower) I think the head gaskets would be the first problem to show assuming the rotating assembly is properly built. Denny @ Sharadon figures my engine should hold 20 psi if detonation is kept in check.
2003 Ram 1500 RCSB 2WD
Turbo Alcohol Injected 392
Old 05-03-2010, 11:25 PM
What kind of components (crank, rods, pistons) did you use in your bottom end turbo392?
Old 05-03-2010, 11:32 PM
turbo392's Avatar
6.1 block & crank, Diamond pistons, Carrillo rods, complete cryo-treat
Old 05-04-2010, 12:33 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
is this on Jerry's truck or someone elses? duh..on yours..
Old 05-04-2010, 01:57 AM
So your running a stock 6.1l crank? Not forged? Hmmmm....
Also anyone know of a GREAT tuner near Central Ohio?
Old 05-04-2010, 02:16 AM
I am also kind of leaning towards 61mm or 64mm Turbos... I might go 64mm just incase if i get bored with it I can turn up the boost a little... I think 57mm or even 61mm turbos might run out of umph up top... what yall think?
If I go 64mm What Exhaust A/R do you think would be best... .50 A/R or .68 A/R? (I can get those same A/Rs in the 61mm too)
Old 05-04-2010, 08:40 AM
turbo392's Avatar
Larry's quadcab that he never finished in time for Monster Mopar last year.
turbo392's Avatar
The 6.1 crank is forged.
Old 05-04-2010, 08:49 AM
turbo392's Avatar
Twins are not needed on these trucks. There is plenty of space (unlike a car) and we don't need high boost like a small engine to make big power. A single large T4 housing will make more than what the drivetrain can handle. I've seen a few twin setups using T60-1 units on older vehicles.
