Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 05-02-2010, 10:42 PM
ShaneInsane ShaneInsane is offline
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
ShaneInsane is on a distinguished road
Default 92 Ram 4x4
Yes, I have a turn signal and brake light that dont work on one side. I have recently bought the truck and have been looking at it trying to figure out what it is and found thast the wiring harness going to the side that is out has been spliced into one wire and looks like it is a ground.. But I am no happy with that at and would like to either fix it or buy a new wiring harness where would I purchase one or how would I go about fixing it .. I replaced the bulb and light socket and still no brake light or turn signal on the driver side.
Old 05-11-2010, 04:40 AM
Cornfed 86 Power Ram's Avatar
Cornfed 86 Power Ram Cornfed 86 Power Ram is offline
Vehicle: 1986 Power Ram 250 4x4
Trim Level: SE
Color: Tan and Brown
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
Rep:30
Cornfed 86 Power Ram is on a distinguished road
I had the same problem I ended up Getting 2 new tail lights and replacing the turn signal relay on the fuse box. When i put the new lights in i just had someone step on the brake and use a test light to find out what wire got power. Im not sure what it was that fixed it but just go by trial and error. As far as the wiring harness goes i have yet to find one myself so if you find one could you let me know
Cornfed 4Life-1986 Dodge Power Ram 250 -360ci LA V8 4 speed- 410 gears
Old 05-11-2010, 09:09 AM
iRESQu iRESQu is offline
Rep:2217
Shane, seeing that this is your first post, I would like to start by Welcoming you to the Forumz! I also noticed that Cornfed jumped in to offer some advice. I am not smart in the electrical field at all, but if you stick around others with that knowledge will chime in. Best of luck!
Old 05-11-2010, 09:22 AM
Rep:1625
Welcome to the forum Shane! We're glad to have you here!
