Old 05-03-2010, 12:04 AM
whiteliftedram's Avatar
whiteliftedram whiteliftedram is offline
Vehicle: 2000 dodge ram 4X4 4 door
Trim Level: slt laramie
Rep:28
whiteliftedram is on a distinguished road
Default i need to get better gas mileage please help
i got a lifted ram im gettin 7 right now i wanna try and atleast get 12 can yal help me? what should i buy?????
817 721 0579 i barely have time to get on here so text me if u can
Old 05-03-2010, 02:17 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Clean out your throttle body and check your intake for oil while you have it off. Belly pan gaskets on the intake are prone to leaking.
Old 05-03-2010, 02:23 PM
Rep:1877
Since your truck is lifted, I assume you have larger than factory tires. Has the speedo been recalibrated for larger tires? If not, you can toss your fuel economy calculations right out the window.
Old 05-04-2010, 08:22 PM
Rep:28
ya its be recalibrated we just cleaned out the tb no oil in intake we replaced tb gasket to
Old 05-04-2010, 08:26 PM
Rep:1625
What size tires are you running? Maybe check the air pressure
Old 05-04-2010, 09:06 PM
ScatPak07's Avatar
Rep:970
If you do not have an intake and exhaust then get those. They will help you out as well. Do the whole exhaust headers all the way to the tip. This will let the truck breath much better which will give you better MPGs. Also tuners will give you some better MPGs since it will make it run totally different. If you do not have a tonneau cover than that would help as well. This will make the truck have less wind resistane due to the tail gate
Those are some steps to take but it does cost a bunch of money.
Old 05-04-2010, 09:07 PM
I push the skinny pedal
Rep:3277
If you upped the tires, you want to re-gear to get some of that torque back to the wheels, and you'll pick up some MPGs.
Kurtis
Old 05-09-2010, 05:28 PM
Rep:28
its got gibson headers true duals hi flow cats and flowmaster mufflers all the way back to 4 inch tips
Old 05-10-2010, 01:09 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
What gears do you have?
brad
Interested in one of my mods?
