Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 01-23-2011, 02:47 PM
Rep:1909
All I'm going to say is that I have NEVER seen a CTD block cracked. I wonder if the people with all these cracked 53 blocks are modding their engines and to what level.
Old 01-31-2011, 10:34 PM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
Here is a little bit about the 53 block, and how to find out if it is in fact a 53 block...
To figure out if you have one of the dreaded "53" blocks, crawl under the front, left side, and look up at the block on the front, directly under the injector pump (by the PS pump). You should see a large wiring harness mounted to the block. Directly below this, just above where the oil pan meets the block you will look for a "53" cast in the block.
With the 53 block, you have pretty much a 50 50 chance that you will end up with a cracked block. Something about that particular casting was not good, and some cracked, while others did not. I would definetly crawl under the truck and check for the stamped "53" before buying.
Scott
2004.5 2500 Quad Cab LB 4x4 with stuff.
Old 02-04-2011, 12:33 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
35's will definitly affect the mpg maybe even up to 3-4 mpg over 31in stockers.
the overhead lie-o-meter went from about 26 mpg to 24.5-25mpg, actual is usually went from 24ish 21-22 mpg
Old 02-04-2011, 12:50 AM
Rep:2657
if you have the good block, just remember diesel engines can be rebuilt several times over, when the cylinders get bored to the point of being too thin, then you can re-sleeve them & start all over again
Big rig diesels can easily have 2 million miles on them
Old 02-12-2011, 09:25 PM
440russell 440russell is offline
Vehicle: 2004.5 dodge ram
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
440russell is on a distinguished road
hey maddog...you read the recent posts?????? can u spell vindication? lol not sure i can but I WAS RIGHT and you were wrong and you cant stand it.....lololololol
Old 02-15-2011, 09:56 AM
79ta 79ta is offline
79ta is on a distinguished road
This month of diesel power mag has an article on the cummins flaws and the 53 block is discussed as is the killer dowel pin issue. It shows you where to look and what to look for with the 53 block and how to fix the dowel pin issue.
cummins
