Old 05-04-2010, 04:41 PM
srtsir's Avatar
srtsir srtsir is offline
Vehicle: 2004 Dodge Ram
Rep:198
srtsir has a spectacular aura aboutsrtsir has a spectacular aura about
Default drop shackles
Is there a how to for drop shackles??Also how do you remove overload spring???what does it look like???
5.7 HEMI, DIABLO, K&N INTAKE, MBRP CATBACK, 4.56 MOTIVE, DMH E-CUTOUTS, 22X10 SRT-10 RIMS (BLACK), 315/45/22 COOPER ZEON XST'S, 2/4.5 MCGAUGHYS DROP KIT, 6K HID'S FOGS & HEADS, RECON L.E.D TAILGATE STRIP, EFX ROLLPAN, TRUXEDO LO-PRO, HORNBLASTERS 156DB TRAIN HORN, HONEYCOMB GRILLE....
Old 05-04-2010, 05:02 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
The overload spring is the very bottom one in the stack. It is below the leaf "pack" and sits on top of the spring perch.
Shackles aren't too bad. Make sure to put the jack under the bumper and get some tension off the springs, not enough to lift the rear tires off the ground though, just enough to make removing the shackle bolts easier.
When you put on the drop shackles, make sure to do the bottom bolt first since it goes on from the inside of the frame.
Old 05-04-2010, 08:07 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
The only problem i found with a drop shackle was it only goes to 2 inch............Thats it.
