Old 05-04-2010, 09:34 PM
09 RT RAM's Avatar
09 RT RAM 09 RT RAM is offline
Rep:39
09 RT RAM is on a distinguished road
Talking Shock info
If you lower using the http://www.mcgaughys.com/ kits here is some shock info.
Ground Force Rear -- 70070 52.40 each from Stylin' (REDUCED LENGTH SHOCK FOR LOWERING KITS)
Bilstein HD Front -- 2009 Dodge RAM 2WD SPORT.
F4-BE5-G779-H0 REAR $67.95 not yet available (STOCK APPLICATION)
F4-BE5-G740-H0 FRONT $74.95 ea., in stock
www.shox.com
Old 05-05-2010, 01:55 AM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default shocks to lower the ram rt -- question
i was also checking shocks for when i lower my truck, what if we use the viper truck shocks?
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 05-07-2010, 02:54 AM
09 RT RAM's Avatar
Rep:39
Lightbulb
you need to check mounting type and length......valving is an art and these freaggin' vendors don't know squat anymore....don't even go into spring rates
Old 07-18-2010, 09:10 PM
09 RT RAM's Avatar
Rep:39
eshocks.com
09-10 Ram 1500 - 2WD
Mono-Tube Gas Front: BE5-G740-H0
Mono-Tube Gas Rear: BE5-G779-H0
Old 07-22-2010, 06:15 PM
SPEEDFREAK's Avatar
Color: SPEED WHITE
Rep:180
Default ram shocks - new
just ordered them in stock on the way
Old 07-24-2010, 03:27 PM
Vectors2Final Vectors2Final is offline
Vehicle: 2010 Dodge Ram R/T
Trim Level: R/T
Vectors2Final is on a distinguished road
Didn't expect Bilstien to be so cheap, the charge so much more money for applications on sports cars. I plan to get some with my 2/4 drop. Any coil kits out there?
Old 07-24-2010, 05:38 PM
SPEEDFREAK's Avatar
Color: SPEED WHITE
Rep:180
Default shocks for ram rt, ram 1500
these just came out # part is f4 be5 g740 ho, f4 be5 g779 ho rear= 09-10 ram bilistine shocks
