ABS, Brake Warning and Check Engine - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-08-2010, 11:40 AM
TsubaMaster TsubaMaster is offline
Vehicle: 2002 Dodge Ram 1500
Color: Auburn/ Crimson red
TsubaMaster is on a distinguished road
Dude its your speed sensor..... its located on the top of the rear diff towards the front of the truck. Oriellys has them for like 30 bucks bro. Do this bud, turn your ignition on but dont crank the truck in this pattern... on, off, on, off, on with in 5 seconds and the odometer will show the trouble code. If its p0500 its the speed sensor. One bolt and unplug the old one, plug up the new on and bolt it down. 30 bucks and 15 min thats it. and to get rid of the engine light disconnecst the positive terminal on the battery and turn the ignition on then off and hook the battery back up. Youre good to go bro.
Old 05-08-2010, 03:03 PM
nashdaddy75's Avatar
nashdaddy75 nashdaddy75 is offline
Vehicle: 2004 Dodge Ram 1500 Quad 4.7L
Color: Blue/Silver
nashdaddy75 is on a distinguished road
I just replaced that speed sensor and it was 55 at advanced. LOL I dont have Orielly's here in VA that i know of. I just tried the on off on off. All that happened was the check engine light flashed at me about 10 times. I think it might be the wiring harness to the speed sensor. I hooked it um to a mulit meter and it was giving me about 35 ohms back. I think it is supposed to be between 3-5. Again just scrating my head over this crap. hahaha
Old 05-16-2010, 02:40 AM
racer965 racer965 is offline
racer965 is on a distinguished road
I had a similair issue with my dash lights coming on, although my turn signals and headlights also didnt work. The problem surprisingly was my key when I turned the ignition it felt real tight. Flipped the key over and the dash lights went out and my headlights and signals worked. Dunno if this is your problem but, it is worth a try since your porblem seems a lil intermittent. Good LUCK!!
Old 05-20-2010, 09:35 PM
Color: Blue/Silver
I am really confused because the lights are out but as soon as the weather is above about 75 the lights come back on. I am also being told that it might be the VSS on the hub. Any more ideas.......?????
Old 05-20-2010, 10:02 PM
Ram98's Avatar
Ram98 Ram98 is offline
Vehicle: '98 Ram 1500 , 2004 Rumble Bee
Trim Level: Sport,Rumble Bee
Color: Blue, Yellow
Rep:28
Ram98 is on a distinguished road
Had problems with my ABS and check engine light coming on turned out to be the brake lite switch, check that. Mine was out of adjustment.
98 Ram 1500 Sport 4x4 5.9L
2004 Ram 1500 4x4 Rumble Bee
Old 07-16-2010, 01:10 PM
01RamMP 01RamMP is offline
01RamMP is on a distinguished road
I'm new here and I'm having an ABS issue. My brother and I just changed the pads on the front last night, now he has no preassure, and the light is on. We drained the lines, refilled/bled them and re connected, any ideas on what it might be?
Old 07-16-2010, 04:00 PM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
You have speed sensors on the hubs that if they are failing can cause an ABS light to come on. Your speed sensor is likely where mine is on the front hub and it is behind the rotor on the front top side of the hub. On my 07, I just bought the ABS speed sensor that goes on the rear axle because my ABS and brake light was coning on intermittently, and it solved the problem. Hope this helped a little but it may be different for your truck. Maybe Randy will chime in and add some light if I am off base here.
Old 07-16-2010, 08:21 PM
Ram98's Avatar
Color: Blue, Yellow
Rep:28
Not sure what you mean by the re connected? Did you check to make sure the pistons in the calipers did stick when forced them in to replace the pads.
Old 07-16-2010, 10:38 PM
I would recommend to ya to start a new thread on your problem . It will get more exposure . Might want to stop by the newbie section and introduce yourself also .
Old 08-24-2010, 11:14 PM
rakers rakers is offline
rakers is on a distinguished road
I also had the abs, and brake light with the spedometer and odometer non functioning. I replaced the abs speed sensor in the differential and fixed each problem. The one I took out would not rotate.
