How To: "Big 5" Basic Engine Re-Wiring Upgrade - Tutorial - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 05-10-2010, 05:15 AM
Rep:4264
I have to agree, excellent writeup with pics, and although like Kurtis, I won't be tackling this, either, thanks for taking the time to put it all together!
Old 05-10-2010, 05:55 PM
pimpshin3 pimpshin3 is offline
Vehicle: 2013 4wd crew cab
Color: Bright silver metallic
pimpshin3 is on a distinguished road
I did this wiring upgrade on my last car (06 scion tC) and it made the car idle ALOT smoother and run smoother. 1/0 guage wire isn't cheap, but a smoother idling engine is worth it to me. Thats not even including the audio system advantages. Thanks for doing a great write up to make it even easier for me to do when i get the chance!
Old 05-10-2010, 10:15 PM
silvermist's Avatar
silvermist silvermist is offline
Vehicle: 08 dodge ram quad cab 1500 4x4
Trim Level: sport
Color: sunburst orange
Rep:37
silvermist is on a distinguished road
the fuseable link acts just like a fuse but can't be esialy replaced like one as if the voltage running through it gets to high the wire over heats and melts to cut current which helps prevent fires, usually the fusable link is 2 sizes smaller then the accual wire you use.
Old 05-12-2010, 05:14 PM
silvermist's Avatar
Trim Level: sport
Rep:37
also have to add that the fusible link melts slower so that it doesn't just melt if you have a sudden voltage spike like a fuse will if your going to add in a fusable link match the lenght of the original one and be careful when sodering it inline as to much heat will melt it.
Old 07-26-2010, 03:20 AM
Valldar's Avatar
Valldar Valldar is offline
Vehicle: 2006 Ram 1500 - 5.7L HEMI 4x4
Rep:63
Valldar will become famous soon enough
Update: fixed up a few of the pictures, had some linking problems on some of them
ERIK
-=UPGRADES=- Focal K2 Component Speakers // 2x Boston G210-44 Subs // 2x JL 500/1 & 300/4 Amps // Rhino Lining Bed // Grillcraft Black Grille // 35w 5000k HID Fogs // 50w 6000k HID Heads // 0 Gauge Engine Wire Upgrade
Old 07-26-2010, 10:44 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
Nicely done man ... u can also just run an inline fuse before the battery from the charge wire if u dont want to hassle running back to the fuse block. Im using a 150 amp fuse there seeing i just have the stock alternator.
Old 08-20-2010, 11:30 PM
wester399's Avatar
Rep:100
sorry i shoulda posted this early the only time i would reccoment fusing the charge line is if your running a high output alternator. Although even then its just an extra safety precaution for those guys running very high current im talking proly 10000 watts plus and when u get into that range ur gonna be running multiple alternators and batterys.
Old 09-20-2010, 04:11 PM
flipster flipster is offline
Vehicle: 2009 Dodge Ram 1500
Color: Brown
Rep:60
flipster will become famous soon enough
Great write up. I never liked crimping, but soldering large guage wires is a pain. It is better for the conductivity though and keeps any chance of a loosening crimp from happening.
As you know, over time with heating and cooling crimps can become loose or even fall out. This may eventually lead to a "high-open" that will only occur when your vehicle wiring gets warm. May want to just go back and solder the connections.
Great pics and write up! REP added...
Old 05-03-2011, 03:02 AM
JDJohnson9's Avatar
JDJohnson9 JDJohnson9 is offline
Vehicle: 2008 Dodge Ram
Trim Level: Mega Cab 4X4
Color: Maroon
Rep:94
JDJohnson9 will become famous soon enough
So i am going to tackle this job this weekend. my question is this. Seeing the fusible link is being replaced with normal wire i am opting for an inline fuse and from what i have seen thats what most do. now with that being said the stock alternator puts out what 136 amps, so what size inline fuse should be used, 150 amp? I will also be bumping up the alternator to a 240 amp in the near future but i will figure out what fuse to use for that later, 250 amp maybe?
Old 10-02-2011, 11:01 PM
voodoochi1d's Avatar
voodoochi1d voodoochi1d is offline
Vehicle: 2009 Dodge ram 1500 slt
Color: silver
voodoochi1d is on a distinguished road
Thanks for the write up and the pics. This is gonna help. Im gonna go get the cable this week, and have a shop crimp the ends. I will then solder them myself and then add the shrink tubing.
