Old 05-06-2010, 04:53 PM
mdbrown mdbrown is offline
mdbrown is on a distinguished road
Default Newly installed HID's causing TPMS light to come on?
Hey guys, ive got a 2010 1500 cc 4x4 with the lone star package..same as the big horn package. i've got quad headlight system so different bulbs for high/low. when i put the hid's in the fogs and lows from our vendor 3bspec, whenever im driving down the road the (!) orange light will come on and say service tpms, and when i look at tire pressures they are all fine except the back right just has two dashes. the problem is that when the lights are off im having no problems whatsoever with the tpms and the tire pressures are all showing up just fine. i tried emailing 3b about it but have yet to get a response. anybody have any suggestions on it?
Old 05-06-2010, 05:08 PM
CustomShirts's Avatar
CustomShirts CustomShirts is offline
Color: White 2-tone
Rep:172
CustomShirts has a spectacular aura aboutCustomShirts has a spectacular aura about
I would suggest sending a private message to Forumz member "operatic" I messaged him a couple of times last week regarding 35W and 50W HIDs for the 2010 Laramie. He was pretty quick to reply.
Which lights did you get? Are you using HIDs for both High and Low Beams as well as Fogs?
- Tim
Old 05-06-2010, 05:13 PM
iRESQu iRESQu is offline
Rep:2217
I haven't a clue. But I will take this opportunity to welcome you to the Forumz. I also agree with what he ^^^ said. Pics always help too. Thanks and see you around the Z.
Old 05-06-2010, 05:53 PM
haha i got ya'll, i just called 3b and their not real sure yet either. i snapped some pictures but their kinda hard to see. i mounted the ballasts pretty close to the bottom of the truck near the frame mounts.
http://img153.imageshack.us/i/img1062v.jpg/
http://img153.imageshack.us/i/img1061i.jpg/
Old 05-06-2010, 09:45 PM
operatic's Avatar
operatic operatic is offline
operatic is on a distinguished road
Are you pinching a wire somewhere with the zip ties?
Old 05-07-2010, 01:29 PM
got it figured out. I ended up moving the ballasts around and it solved the problem.
Old 05-07-2010, 03:17 PM
operatic's Avatar
Weird... if you can, post a picture of where you moved it to.
Old 06-10-2010, 10:38 PM
WhiteRamSport's Avatar
WhiteRamSport WhiteRamSport is offline
Rep:35
WhiteRamSport is on a distinguished road
I'm having the same problem. When you say moved around did you move the ballast or did you move the wiring and switch the polarity?
Please give me more details as I am very aggravated with the TPMS issue.
Old 06-12-2010, 12:06 PM
operatic's Avatar
He relocated the ballast itself.
Old 06-12-2010, 12:09 PM
Musta pinched something off or the connection wasn't fully seated somewhere.
