Old 05-07-2010, 08:25 PM
JR23 JR23 is offline
Vehicle: 2003 Quad Cab 2wd 5-speed
Color: Maroon
JR23 is on a distinguished road
Default Shudder under a load
Just had a real bad shudder in driveline while hauling a load of landscape rocks (500lbs) to the house. 1st gear a little rough, but when I went into 2nd..OMG what is that? I thought the driveshaft was going to drop! I actually stopped and looked underneath because i though something was rubbing. So, I have nursed it home (it eased up as I gained a little speed, still bad @ takeoff). My thoughts have been : U-joints; clutch; rear end; maybe drive shaft?
As always thanks for the advice!!!!
Old 05-08-2010, 07:29 AM
Rep:1885
I'd start by dropping the drive shaft and checking the u joints for binding, looseness and lack of lubrication.
Old 05-08-2010, 03:14 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
If its dropped, is there a pinion shim in it?! I am thinking if its lowered a little, and it had a big load, there was some major misalignment/binding.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 05-08-2010, 05:04 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
500 lbs isn't much weight. Definately look at the U Joints. I had one go bad in my truck, however it started to vibrate at high speed. Aftermarket ones have grease fittings as a rule, also.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
