Old 05-09-2010, 12:55 AM
ScatPak07's Avatar
Rep:970
Originally Posted by mholla00 View Post
Well... the 6" inch lift to fit 35's comment may be true for a chevy but you can fit 35's on rams at a stock height believe it or not. I have a 2wd 08 ram 1500 at stock height and I run 35 12.5 20 mudgrapplers on liquid metal wingman wheels. I didn't trim anything or do any other modifications except mounting and balancing the tires on the truck. Granted the offset of the wheels may be the reason for them fitting so with a stock 20" wheel you may need to run a spacer. But on the 06-08 body style you can fit up to 35 12.5's at a stock height even on a 2wd, bwy: no rubbing even at a full turn in reverse
I have a 2007 Dodge Ram with a 2" lift and I have 33" tires. I have very little space at full lock. I guess if you say 35s can fit then I guess I am wrong. I am going off of what I have experienced so that is where my comment came from. I know I can put 35s under mine since I do have some room left.
From what I see from manufactures and their specs the 35s can not fit unless you have a lift. You also have aftermarket rims which gives you some offset. That would put the tire away from the truck which would give you that added room you would need
Old 05-09-2010, 12:57 AM
ScatPak07's Avatar
Rep:970
Originally Posted by SUL7ENAZ View Post
That is totally inaccurate. While 2wd dodge's sit lower than the 4wd's they are much cheaper to lift & a 2wd truck will go just about anywhere in the dunes. Trophy trucks that win the baja races are 2wd drive. It is much simpler to lift a 2wd since you don't have a half diff and half shafs in these ifs torsion bar trucks of the same year. Check out CST suspension. They make a bad ass kit at the fraction of the price of comparable 4wd lift kits.
Sorry I did not know that. I heard other wise from someone else. I guess I was missinformed.
I am really sorry for giving inaccurate information, I feel like an idiot haha.
Well I will be talking to that person tomorrow and I will let them know they made me look stupid. I might have to give him a smack on the back of the head
Old 05-09-2010, 01:08 AM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
BTW Any one with an 02-05 2wd or 4wd can benefit from a set of cst suspension upper control arms. They are listed only for the 2wd but I've installed a set on a 4wd and they work (2WD & 4WD UCA's are the same). when installed with a leveling kit they take stress of upper ball joints and help align more accurately allowing you to crank just a tad bit more without sacrificing ride quality. You'll need to buy longer shocks and bump stops so you don't bottom out. These arms are a great addition to any lift like fabtech, rough country, pro comp etc. Def. Worth the money.
SUL73NAZ
Old 05-09-2010, 07:44 PM
RumbleBee05's Avatar
RumbleBee05 RumbleBee05 is offline
Vehicle: 2005 Dodge Ram 1500
RumbleBee05 is on a distinguished road
Ill I have to get new arms and ball joint for a 6in suspension lift? That could be out of my price range.
05 1500 flame red 5.7 HEMI super charged 400hp
Old 05-09-2010, 07:52 PM
Also would I need a leveling kit first then new shocks? Or do I have to get new springs and all that jazz? also would a spacer be needed if I am using stock 20s to not rub any? I maily just want to raise the front to match the back and mabey lift the whole truck 3in. Anyone know what size tires I could fit then? And how expensive is it to get tires to fit the 20s.
Old 05-09-2010, 08:33 PM
HORNYHEMI's Avatar
HORNYHEMI HORNYHEMI is offline
Rep:16
HORNYHEMI is on a distinguished road
Fitting 35s doesnt just go off of height. Alot of fitting a bigger tire is the width of the tires also. I know I have read about stock dodges running 35 12.50s. But most of the time this isnt the case. Now after saying that i will just put in my two cents about the whole thing. I see you have a supercharged truck? What kind of supercharger is it? If i had a supercharged 2WD id be going down and making it fast through the corners and alot more fun at a track and even get better mileage. I am just a huge fan of lowered 2WD pickups and lifted 4x4s. But if you go the lifted route im sure one of these guys will stear you in the right direction, your in good hands here.
Old 05-09-2010, 10:58 PM
SUL7ENAZ's Avatar
Color: blue
Rep:463
Rumble Bee, You can start by just adding the 7" CST Lift for 2wd 02-05 hemi's which will include 4" spindles, a 3" coil spring spacer and a block and you bolt kit for the rear. Later on you can upgrade the upper control arms. After getting the arms if you would like then you can add the larger rough country springs (the arms are necessary to run these if you decide to lift it higher). CST has part numbers for shocks for their 7" kit. You will need to run longer shocks (than the ones cst has part numbers for) if you do the bigger springs. The base 7" kit is only $1200
SUL73NAZ
Old 05-10-2010, 12:29 AM
Is the cst kit a adjustable shock? I don't think I want to go up 7in. I was thinking more of 4-5in.
Old 05-10-2010, 12:32 AM
Hornyhemi, I have no clue what brand it is. When I bought the truck it was already installed. There are no markings on it so I can't tell what it is. I considered lowering it at one point but I go hunting and fishing in this truck as well as pulling trailers of all kinds so lowering is out of the question.
Old 05-10-2010, 09:39 AM
SUL7ENAZ's Avatar
Color: blue
Rep:463
Rumble Bee, If all you are looking to do is level the truck then all you need is a set of CST's Lift spindles. You do not need longer shocks to run just the spindles. The UCA's still remain optional. I would start with the spindles. Get your tires. You can hold off on shocks and UCA's until you need them. Just the spindles installed will be less than $1000
SUL73NAZ
