Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 05-08-2010, 10:57 AM
awful knawful awful knawful is offline
Vehicle: 2009 RAM 1500 CC 4X4
Rep:24
awful knawful is on a distinguished road
Default changing clockspring
does anyone know how it's done? do I need a steering wheel puller?
Old 05-08-2010, 11:32 AM
Rep:1909
REMOVAL
WARNING: To avoid serious or fatal injury on vehicles equipped with airbags, disable the Supplemental Restraint System (SRS) before attempting any steering wheel, steering column, airbag, seat belt tensioner, impact sensor, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the SRS. Failure to take the proper precautions could result in accidental airbag deployment.
CAUTION: Always turn the steering wheel until the front wheels are in the straight-ahead position. Then, prior to removing the clockspring from the steering column or disconnecting the steering column from the steering gear, lock the steering wheel to the steering column or securely fasten the clockspring rotor to the clockspring case. If clockspring centering has been compromised for ANY reason, the entire clockspring and Steering Angle Sensor (SAS) unit MUST be replaced with a new unit.
<A xmlns="http://www.w3.org/1999/xhtml"> 1.Place the front wheels in the straight ahead position.2.Disconnect and isolate the battery negative cable.3.Remove the driver airbag from the steering wheel. 4.Disconnect the steering wheel wire harness connector from the upper clockspring (3) connector receptacle.5.If equipped, disconnect the clockspring pigtail wire connector for the steering wheel heater element from the steering wheel connector receptacle.6.Remove the steering wheel from the steering column (1). 7.If the removed clockspring is to be reused, be certain to secure the clockspring rotor to the clockspring case to maintain clockspring centering until it is reinstalled on the steering column. If clockspring centering is not maintained, the clockspring and Steering Angle Sensor (SAS) unit must be replaced with a new unit. 8.Remove the upper and lower shrouds from the steering column. 9.Remove the two screws (2) that secure the clockspring to the steering column housing.
<A xmlns="http://www.w3.org/1999/xhtml"> 10.Pull the clockspring rearward away from the top of the steering column far enough to access and disconnect the following instrument panel wire harness (7) connectors and their wiring retainers from the clockspring, as the vehicle is equipped: a.Multi-function switch connector (1)b.Heated steering wheel slip ring connector (2)c.Steering Angle Sensor (SAS) connector (3)d.Two clockspring connectors (4 and 5)e.Adjustable pedal switch connector (6).11.Remove the clockspring from the steering column. The clockspring cannot be repaired. It must be replaced if ineffective, damaged, centering has been compromised or the driver airbag has been deployed.12.Remove the multi-function switch from the clockspring.13.Remove the adjustable pedal switch blank filler or switch from the clockspring.
Old 05-08-2010, 05:27 PM
Rep:24
Thank you very much. You save me alot of headaches lately with your helpful responses to my posts.
Shawn
