Old 05-08-2010, 09:22 PM
Scotty1500 Scotty1500 is offline
Vehicle: 2000 dodge ram 1500
Color: red
Scotty1500 is on a distinguished road
Default play in steering wheel on lifted truck
so i have a 6in lift in my truck with 36in tires, i replaced the sway bar bushings, have radial tires on it, i know that there will be some play in the steering wheel from the lift but is there anyway to not have any play in the steering wheel?
Old 05-08-2010, 09:55 PM
Do you have a steering stabilizer?
Old 05-09-2010, 12:42 AM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
I would install a steering box brace. DT Profab and BD Diesel both offer nice ones that fit your year truck. It will help much more than a shock type stabilizer will. If you absolutely want to lose the play in your steering wheel install hydraulic ram assisted steering. I installed the complete agr rock ram kit in my truck bud offroad unlimited and psc motorsporst also sell nice kits. They will make sure your tires stay aimed where they need to but it's gonna cost you. Kits run around 2000$ for a complete kit with reservoir, gear box, ram, lines etc.
SUL73NAZ
Old 05-09-2010, 12:58 AM
ScatPak07's Avatar
Rep:970
You may want to get that taken care of before the death wobble kicks in.
The two recommendations above are the best solutions for the problem.
Old 05-09-2010, 08:46 PM
HORNYHEMI's Avatar
HORNYHEMI HORNYHEMI is offline
Rep:16
HORNYHEMI is on a distinguished road
What makes you think a lifted truck is going to automatically have steering play? How much play are we talking about, you could have bad tie rod ends.
Old 05-09-2010, 09:16 PM
iRESQu iRESQu is offline
Rep:2217
I have an 08 lifted on 37 and had bad play in the steering. A friend of mine looked at and my Dodge Tech confirmed, that a certain piece just needed adjustment/tightening. It was after another Dodge dealer replaced my steering gear box and didn't tighten the pittman arm/bolt back in place. That was all I needed. Hold tight and hopefully someone with this name will chime in to confirm this. I am not a pro.....I can only offer my advice of what happened to me. Best of luck and hopefully this is all that it is for you. BTW I have 24,000 miles on my truck.
Old 05-10-2010, 09:47 PM
Color: red
i have a 6in lift on my truck lol, its not to bad but i want to get it to drive like a normal car, it only moves like 2in each way and the tires dont move, i replaced the sway bar bushings and it helped out with the handling but ill look and see, ill run down to dodge and see bc my friends works there
Old 05-11-2010, 01:57 PM
HORNYHEMI's Avatar
Rep:16
There are alot of factors that can play a roll in steering play or what can seem like steering play. Bad suspension componants, outer tie rod ends and inner tie rods will cause play, wheel bearings will cause play if worn or bad. Upper and lower ball joints can cause this also. What ICOVERU said is a very good point but my truck being a 1/2 ton doesnt have a steering box or pitman arm or idler arm and so on. I just have a simple rack and pinion. Installing a tire on a wheel that is narrower than the tire can also make it seem like you have steering play and cause a decrease in steering response. But if you do have a problem which 2 inches is quite a bit in my opinion i hope you get it figured out.
Old 05-11-2010, 02:10 PM
Rep:1885
Older gearboxes need occassional adjustments and track bars are notorious for problems but I would think yours isn't stock with a 6 inch lift under it. Either way, it could be bad.
Old 05-11-2010, 02:15 PM
Rep:2217
Thank you, I didn't catch that. Sorry guys.
