Old 05-09-2010, 12:47 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
Default rear disc conversion (3g parts on a 2g)
Not really sure what forum this belongs in...but...
I have a 98 Ram SS/T and it has rear drum brakes.
What I'm wondering is, there is a 2003 Ram with rear disc brakes at the local junkyard.
Since the rear ends are both the spicer 9-1/4 and they are the same lug pattern, would I be able to simply swap the newer brake setup onto the older truck?
I realize I would have to change the master cylinder and probably the proportioning valve as well...
but...should it bolt right up, no hassle?
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 05-09-2010, 05:45 PM
Rep:210
bump.:.:.:.:.
Old 05-09-2010, 06:53 PM
droshemiram's Avatar
droshemiram droshemiram is offline
Vehicle: 03 dodge ram HEMI
Color: atlantic blue
Rep:89
droshemiram will become famous soon enough
I think there should'nt be a problem on your 98 do the leafs sit on top of the differential?
Old 05-09-2010, 07:19 PM
Rep:1845
I'd measure the spring perches first to be sure but I think everything will fit pretty easily.
Old 05-09-2010, 08:57 PM
Rep:210
I wasn't planning on swapping the whole rear...just the brake hardware.
But...maybe if it has 3.92 gears...I may
the springs sit on top of the rear, which I was thinking about changing anyway to lower it...not sure yet.
But, if I were just to swap over the brake hardware...would it bolt up?
