For Sale or Trade: Nightshaded 07 Tails WITH PigTails! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Buy - Sell - Trade > Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy!
Closed Thread
Old 05-09-2010, 10:15 PM
MOPAR MULiSHA's Avatar
MOPAR MULiSHA MOPAR MULiSHA is offline
Vehicle: 2012 Dodge Ram 1500
Color: Sage Brush Pearlcoat
Rep:219
MOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura about
Default For Sale or Trade: Nightshaded 07 Tails WITH PigTails!
As some of you have read I downgraded to 05 Tails and I just nightshaded my old 07's today, tomorrow I'll be polishing them when I get home from work.
I'll trade for a set of Electric & Heated Tow Mirrors or will do $80 SHIPPED.
As stated in the title they come with all the Pig Tails so if you're upgraded from 02-06 you'll have them to splice into & the 3rd brake light is just plug and play for that.
2012 Sage Brush Pearlcoat Ram 1500 Big Horn Crew Cab Hemi 4x4 w/ Ram Box Storage System
Old 05-09-2010, 10:25 PM
G'Luck with the sale!
So what did you do to wire up the 05's so they worked on your '07?
Old 05-09-2010, 10:34 PM
Rep:219
Well with the 05's having 3 bulbs & different pig tails (well it was actually a plug into a long assembly mounted to the back of the light) and it had 5 pins also (tail lamp wiring has 5 wires) so I just wired it straight to the tail lamp plug. The 07 tails only have 2 bulbs ( but like i said 5 wires so they pretty much match up), the pig tails have a few inches of wire so they can be spliced in, just a matter of using a test light to find which light is which but there are 2 grounds ( 1 for the reverse light & the other for the main light)
Old 05-09-2010, 10:38 PM
ahhh...got it.
So did you use both bulbs on the tail lights then?
What I am thinking about doing is that the top two become tail, stop and turn signal lights vs. the stock configuration.
Old 05-09-2010, 10:46 PM
Rep:219
ahhh...got it.
Yeah just as if it were like that from the factory.
And do away with the middle bulb? you might be able too just splice the 3 wires together. That assembly on the back of the tails I mentioned before is sealed TIGHT I couldn't for the life of my pry it apart, so it might work if make that adjustment to the wiring before the harness plugs up.
Edit: Just saw you have an 07, what tails do you have?
Old 05-09-2010, 10:50 PM
No...I plan on using the top two bulbs on EACH tail light, having a total of four bulbs as tail/stop/turn.
With the pigtails on the back of the 05 tails it should be a simple splice job.
I have the stock '07 bulbous tails...
Old 05-09-2010, 11:14 PM
Rep:219
Here's what the 05 tail assembly looks like, I'm not too sure it'll work. But you tell me lol.
Old 05-09-2010, 11:31 PM
Looks like either splicing before you get to the pigtail or break that sucker open and run more wires.
Old 05-10-2010, 05:43 PM
Rep:219
Bump to get this thread back on topic!
Old 05-12-2010, 08:34 PM
2007Ram1500's Avatar
2007Ram1500 2007Ram1500 is offline
Vehicle: 2007 Dodge Ram 1500 4.7
Color: Grey
Rep:63
2007Ram1500 will become famous soon enough
Just a question i also have an 07 will these just be a plug and play kinda thing to put back on an 07?
Closed Thread
