Old 05-10-2010, 04:03 AM
peej03 peej03 is offline
Gender: Not Specified
peej03 is on a distinguished road
Default R/T wiring harness question
I have been looking for a 01-03 5.9 to swap into my jeep wrangler. The guys who specialize in the swap said I need 01-03 to match my TJ's 03 sensor.
I found a 99 dakota R/T. I am wondering if I can use the 5.9 and parts (Everything minus the wiring harness and computer) And then find a 01-03 computer to use instead.
Any ideas on this? I have been trying to find info, I am getting desperate so I figured I might have some luck here
Old 05-10-2010, 08:11 AM
Rep:1909
The engines are the same. Some of the sensors may be a bit different so you'd need sensors that match the year of the donor PCM.
Old 05-10-2010, 02:51 PM
Will the 99 engine work with 01-03 wiring harness?
Old 05-10-2010, 03:59 PM
Rep:1909
Should work just fine. There's a small chance you may need to change a sensor or plug here and there.
Old 05-13-2010, 09:15 PM
Can you buy new wiring harnesses? Or would I need to find one off a truck?
I just found an 01 auto 360. But I want to go manual. Is there a place that sells wiring harness and computer?
Old 05-13-2010, 09:56 PM
Might try a junk yard .
