White smoke at start up - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 05-10-2010, 05:11 PM
Resident Technician
Rep:1915
No, too much fuel would cause black smoke. Might be time to do a chemical test to check for combusion gases entering the cooling system. If it's positive then you can do a leakdown test to isolate the problem cylinder(s).
Old 05-10-2010, 06:22 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I checked the oil level............Good..............My coolant level was down some..........Not alot...about a inch.....Im not possitive but it looks to be the same for awhile. I topped it up and i will keep a eye on it. No smoke today at start up or when i got home from work...Just the morning.?????????????
Old 05-10-2010, 06:40 PM
Resident Technician
Rep:1915
How long does it smoke after startup?
Old 05-10-2010, 06:41 PM
bones64's Avatar
Rep:659
Maybe 3 to 6 seconds............Not real long and just enough to notice.
Old 05-12-2010, 09:37 AM
Resident Technician
Rep:1915
Any chance that smoke is gray instead of a pure white?
Old 05-12-2010, 09:51 AM
bones64's Avatar
Rep:659
It could be............Havent noticed any in the past 2 days......Like it happens when i start it up.......move the truck and start it up again within a few minutes.???????????????/
Old 05-12-2010, 10:04 AM
Resident Technician
Rep:1915
That really makes me lean toward valve seals which wouldn't come as a big surprise on and engine with some miles on it. When you have time, pull a few plugs and check for a white/grayish buildup on the plugs. This could be a sign of some oil burning which could indicate the valve seals are going bad.
Old 05-12-2010, 02:10 PM
bones64's Avatar
Rep:659
Thanks Randy.......I should be able to pull a few in the next little while. I will let you know what i find.
Old 05-12-2010, 02:12 PM
Resident Technician
Rep:1915
If you can get some good close up shots of the plugs and post them, it might be helpful.
Old 05-12-2010, 02:48 PM
bones64's Avatar
Rep:659
OK..........Will do.
