tonneaucovered.com
Old 12-05-2010, 05:53 PM
bigred bigred is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: crome
Color: infernal red crystal pearl
bigred is on a distinguished road
well I had better pick up with my 4.10 s but they got so moisey pulled them out coundnt hear the radio the 3.21 s are back in and uselass slide all over in the rain and spin the tiers trying to get going ! so may go to 3.90 s oem but hope no problems there too ! motive is sending me a new set ( for sell anyone ? ) still need to pay my 700.00 loss it will be a while to get them put in . sad they just dont make gears like they use too ! the shop said its been like this for 4 years ! my 3.73 they put in never had a problem ever !! 5 years ago !
Old 12-07-2010, 09:54 PM
thedraco's Avatar
thedraco thedraco is offline
Vehicle: 2010 Ram 1500
Trim Level: SXT Crew
Color: Inferno Red
thedraco is on a distinguished road
I had a Jeep TJ with a 3.73 danna 44, howled since the day I bought it, 45,000 kms, until I traded it in shortly after blowing out the rear end for towing too heavy of a trailer for 8 hours through the sand (80,000Kms).
I got my Ram at 216 kms, now it's got just over 8,000 kms, and has howled since the day I bought it too.
Old 12-08-2010, 09:41 PM
gsrtroy gsrtroy is offline
Vehicle: 2010 RAM R/T
Trim Level: sport R/T
Color: Inferno Red
gsrtroy is on a distinguished road
my ram r/t has did this since day 1 has the 4.10 gears, dealer blamed it on the new intake design and told me they hear it in all of them. I got a exhaust on now and i dont hear it any more even when cruising and my exhaust is quite, but its gone as far as i know.
2010 RAM R/T
Old 12-10-2010, 12:45 AM
Histotoxic Histotoxic is offline
Vehicle: 2010 Ram QC
Trim Level: TRX4
Color: White/Gray
Histotoxic is on a distinguished road
i have a 2010 TRX4 and at 2k miles i would get a howl from 40 to 55 when im on the gas when i let off it goes away. I took it in for it they rebuilt the rear end and it went away. Then after another 1k it came back i took it in and they rebuilt the rearend again. I got in the truck and drove home and it was still there took it in the next day. The dealer now says its normal noise and they will not do anything since a brand new one had the same noise. They said if it gets worse or fails they will warranty it. So now I have had a truck for 7k miles that howls from 40 to 55 mph but no worries its normal. What BS!
Old 12-16-2010, 11:16 PM
william smith william smith is offline
william smith is on a distinguished road
Default rear end howl
Had the same howling noise in my 2010 ram. The dealer changed the whole innards of the rear axle. Everything was new except the housing. I have no howling now. They said it was bad bearings.
Old 12-17-2010, 10:31 PM
jt10hemi jt10hemi is offline
Color: mineral grey
Rep:23
jt10hemi is on a distinguished road
I have just over 15000km on my 2010 sport 4x4 and since the temps have dropped into the negatives I have started to hear a low howl at lower speeds, everything was quit until winter hit.
Old 12-17-2010, 11:05 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
it was prob the same tech setting up the gears each time.
Old 12-18-2010, 01:23 PM
sj1400 sj1400 is offline
sj1400 is on a distinguished road
My 3.92 starts howling around 40mph. I can really hear it good at 50mph with the radio off. Been like tat since day 1. The 3.55 truck I test drove before buying mine did not have this issue. Will switching to Amsoil in the differential cure this or a dealer visit ?
2010 Dodge Ram ST 4x4 Quad Cab Hemi
2007 Dodge Charger RT with R&T
Old 12-20-2010, 09:06 PM
Trim Level: TRX4
Color: White/Gray
Truck is at dealer is at the dealer for its third rebuild since new only 7700k miles. It was deemed normal by the last dealer, and it was getting louder so I took it back in. They are rebuilding the rearend again. My symptoms are the same that I have seen others mention. Howling starts at 40mph and gets louder as speed increases the loudest being at 50 mph then it starts to go down at higher speeds. This is only when you give it gas once you let off it doesnt do it anymore. So I hope this is finally fixed I guess I find out tomorrow. If not I will have no choice but to start the lemon law on it.
