Old 05-11-2010, 05:24 PM
Honda125 Honda125 is offline
Honda125 is on a distinguished road
Default Headlight and tail light issues
About a month to a month and a half ago I got a new 2000 ram. I got rid of the stock head lights and installed halos. I wired the halo lights, 3 LEDs, and the "eyebrow" strip to the parking lights. They worked fine for about two weeks. For whatever reason, the main headlights would not work when I plugged the harness into the harness on the truck. I ended up splicing the high beam light into the regular driving light, so my high beams were on whenever my headlights were on. Then all of a sudden the halos stopped working....the fuse popped and when we try to put a new one in that just pops instantly (power is off). Then a week later my headlights decide to stay on full time (pretty dim though). This includes when the switch is off and even when the truck is off. I have to disconnect the ground from the battery for them to turn off. When I turn the light switch dial to the far clockwise position (headlights on), the driver's side light turns 100% off but the passenger side turns 100% (full power) on. WHY?! Everything used to work just fine, I do not know what is going on or what changed. Also my fog lights do not turn on at all anymore. They used to turn on by pulling the light switch dial (I don't know the actual name for this thing...) out while in the parking light position or driving light position. When I pull the bar to the left of the steering wheel (supposed to activate high beams), all my lights go out.
Also, for whatever reason I have brake lights but no tail lights. Any ideas? I would love to get this figured out...all of this is frustrating. :-/
Old 05-11-2010, 05:29 PM
Rep:1625
Welcome to the forum! Glad to have you here! Sorry to hear about your problems, I would chime in, but I'm not the most electrically savvy when it comes to this stuff. But hang in there, there's plenty of other members who can hopefully provide some info
Old 05-11-2010, 05:32 PM
RamTech RamTech is online now
Rep:1909
If the fuse is popping as soon as you put it in, you need to start searching that circuit for a short to ground.
Old 05-11-2010, 05:49 PM
Okay I'm going to be taking the lights back out because I want to make it right as far as making the high beams the high beams...I will look for shorts then...I just cant seem to figure out why my lights wouldn't work before when I plugged the harnesses together?
Old 05-11-2010, 08:12 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Welcome to the site.
Got a pic of the lights? I would also look for the short some where, I have my leds/halos wired to a switch rather than with the parking lights.
Old 05-15-2010, 12:21 AM
Any ideas on the tail lights? Where do they get tail light power from? Why is power not reaching them?
Old 05-15-2010, 01:28 AM
Rep:1930
I would check the bulbs on the taillights. Either replace with new or make sure they are in the harness good. I had mine not work but the bulb wasn't positioned correctly in the harness.
Old 05-15-2010, 07:44 PM
EARLJAM's Avatar
EARLJAM EARLJAM is offline
Vehicle: 1998 Dodge Ram 1500 Quad 4x4
Trim Level: SLT Laramie
Color: Intense Blue Pearl
EARLJAM is on a distinguished road
my guess is that the wires are crossed somewhere causing a short. i'd go with werm on this one and wire the halos to a switch seperate. then just wire the other headlights normal.
1998 Dodge Ram 1500 SLT Laramie 5.9l Intense Blue Flowmaster Exh. more to come.
