Old 05-19-2010, 03:13 PM
Looks like it brought it down quite a bit . Hows the ride ?
Old 05-19-2010, 04:27 PM
srtsir's Avatar
srtsir srtsir is offline
Vehicle: 2004 Dodge Ram
Rep:198
srtsir has a spectacular aura aboutsrtsir has a spectacular aura about
Is it hard to remove overload spring??? How do you do it???
5.7 HEMI, DIABLO, K&N INTAKE, MBRP CATBACK, 4.56 MOTIVE, DMH E-CUTOUTS, 22X10 SRT-10 RIMS (BLACK), 315/45/22 COOPER ZEON XST'S, 2/4.5 MCGAUGHYS DROP KIT, 6K HID'S FOGS & HEADS, RECON L.E.D TAILGATE STRIP, EFX ROLLPAN, TRUXEDO LO-PRO, HORNBLASTERS 156DB TRAIN HORN, HONEYCOMB GRILLE....
Old 05-19-2010, 04:34 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I see what you mean........Obvious difference..........Looks good man. Thanks for the pics.
Old 05-20-2010, 02:37 PM
pa03hemi's Avatar
pa03hemi pa03hemi is offline
pa03hemi is on a distinguished road
the ride is the same, and for the removal of the overload spring. step 1 put a jack under the rear end right under the shock on the axle and jack the truck up. also put a jack stand under the frame between the rear wheel and front door. step 2 take the wheel off and remove the u-bolts,then you have to remove the center bolt that holds all the leaf springs together. to remove that bolt you might have to lower the jack the whole way down(make sure your jack stand is under the frame). step 3 remove the overload spring which is the very bottom one, little prying and wiggling. step 4 put the rear end back together and do the same on the other side. hope this helps srtsir.
Old 06-07-2010, 02:57 PM
sport14692's Avatar
sport14692 sport14692 is offline
Vehicle: 2011 Dodge Ram
Rep:42
sport14692 is on a distinguished road
Send a message via Yahoo to sport14692
Plan on putting mine on saturday
Sport14692 OUT !!!
Old 09-01-2012, 07:57 AM
ClownShue's Avatar
ClownShue ClownShue is offline
Vehicle: 2008 RAM
Trim Level: Regular Cab 4X4
Rep:19
ClownShue is on a distinguished road
I came across this thread while searching for info on dropping the rear of the truck. I wanted to know how you guys felt about the leaf removal after living with it for a year. I have a reg cab 4wd that I just installed shackles on and the drop is about 3/4 inch. I really want the level llook but do not want to compromise utility/ride quality. also have you noticed any difference in tire wear.
thanks for any input,
David
Old 09-06-2012, 10:38 PM
rdakota340 rdakota340 is offline
Vehicle: 2003 Dodge Ram
rdakota340 is on a distinguished road
David
Yes I did the same I bought the ones off ebay and only seen a 3/4'' difference from original height I took them back off and got my money back did not know I needed to take out the over load spring my truck has 3 3/4'' between front and back.
Old 09-10-2012, 06:08 PM
ClownShue's Avatar
Vehicle: 2008 RAM
Rep:19
rdakota340 Quote:
"Yes I did the same I bought the ones off ebay and only seen a 3/4'' difference from original height I took them back off and got my money back did not know I needed to take out the over load spring my truck has 3 3/4'' between front and back."
I used the Ground Force kit and only got 3/4 inch drop, I guess these guys aren't around anymore to comment on the change in ride over the long haul with removal of the overload leaf.
David
Old 09-10-2012, 07:07 PM
TheSatinPumpkin's Avatar
Color: Satin Orange
Rep:597
had 2" shackles and overloads done 6-7 years ago and it took away a lot of the corner wheel hop that was experiencing at stock height. I haul a few hundred lbs of pet food once every few weeks and the leafs are ok long term.
Old 09-11-2012, 12:02 AM
ClownShue's Avatar
Vehicle: 2008 RAM
Rep:19
"had 2" shackles and overloads done 6-7 years ago and it took away a lot of the corner wheel hop that was experiencing at stock height. I haul a few hundred lbs of pet food once every few weeks and the leafs are ok long term. "
Thanks for the feedback!
David
