Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 05-12-2010, 10:04 PM
lifted47 lifted47 is offline
lifted47 is on a distinguished road
Default 2003 ram 1500 over heated
rmy 2003 dodge 1500 over heated when i was going down the freeway i got it home and changed out the thermostat and the radiator and now it wont idle so i changed out the spark plugs and now it wont idle still i got a check engine light for my tps would that be doing all this cuz my head gasket is still in tacked i dont have creamy oil and there wasnt any coolant in my spark plugs so could my tps be the cure to all this
2003 4.7L
Old 05-12-2010, 10:27 PM
Rep:1625
Welcome to the forum! Glad to have you here! Sorry I'm no help, I'll leave this one to the professionals on here
Old 06-10-2010, 10:51 AM
GaryGtx GaryGtx is offline
Vehicle: 2002 Dodge Ram quad cab 4.7l
Color: light blue
GaryGtx is on a distinguished road
nope could be temp sensor! the old 5.2 and 5.9 had 2 sensors one for the temp gauge and one for the pcm. If the one for he pcm went out then the motor would not ever idle! not sure if the 4.7 isthe same way but it sounds like the same issue.
Old 06-22-2010, 10:40 AM
fixitfirstime's Avatar
fixitfirstime fixitfirstime is offline
fixitfirstime is on a distinguished road
So if you unplug the temp sensor and put it in open loop does it run better and idle then?
Old 06-25-2010, 11:01 AM
RamCountry's Avatar
RamCountry RamCountry is offline
Vehicle: 2006 Dodge Ram
Trim Level: Reg. Cab Laramie 4x4
Color: Atlantic Blue Pearlcoat
Rep:64
RamCountry will become famous soon enough
it wouldnt make it any better open loop makes it think its 52 below so it makes it super rich and usually bogs it out at least on most cars its that way lol you need to take it to a shop that has a scanner that can read real-time data and see what it says
Old 08-28-2010, 01:33 AM
DodgieDan DodgieDan is offline
Vehicle: 2009 Ram 1500 Quad Cab Hemi
Color: Inferno Red
DodgieDan is on a distinguished road
Need to know what codes you are getting with the check engine light much easier to diagnose a problem using them then just guessing it needs this that or the other thing to fix it.
