Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Dodge Ram Decals
Old 05-13-2010, 06:34 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
Default 02-05 srt bumper cover over chrome
the srt bumper cover will fit over the chrome and doesn't need the sport beam to be installed. i've put them on two rams so far.
parts needed
-bumper kit 5030101ab
-retainer 5029625ac
-retainer pins 6502871 x5
-srt grilles, dont have the number off hand
-clips to hold grilles to bumper
1 - remove and save the 4 torx bolts (2 on each side) that hold the top cover on. remove the cover
2 - remove the botttom plastic air dam - 5 10mm bolts from inside the bumper
3 - remove fog light bezels
4 - scuff the chrome bumper in the middle piece (where the license plate holes are) from fog light to fog light as well as the chrome end caps in the inner fenderwell.
5 - paint where you just scuffed flat black - i used rattle can hi-temp bbq paint
6 - attach retainer to top of chrome bumper - all the holes line up perfectly
7 - test fit bumper cover, place the 5 pins through the top of the cover and retainer on the end caps snug the top torx screw you removed earlier through the top hole in the cover - it lines up perfectly.
8 on each side push the cover in slightly - through the second hole down mark the chrome bumper to be drilled
9 remove srt cover
10 on the inner fenderwell where the 2 torx bolts came from - remove the bottom metal threaded clip place the clip on the chrome bumper where you just marked. through the center of the clip punch a dimple - remove clip and drill a 5/16-3/8 hole - place clips over holes
11 put cover back on truck - put the 5 pins in and this time tighten them. on the end caps put the torx bolts in and tighten
12stand back and enjoy
then, you can get creative with the extra unused mounting holes.
i mounted amber led's and wired them to the turn signals.
Old 05-13-2010, 07:59 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
That looks saweet on your truck man...............Awsome. Bumper covers are the way to go! I have one as well not like yours but it fit great.
Old 05-13-2010, 10:52 PM
Looks great .
Old 05-14-2010, 09:22 AM
Rep:1625
Looks good
Old 05-17-2010, 03:19 PM
speeddemon38b's Avatar
speeddemon38b speeddemon38b is offline
Vehicle: 2003 DoDgE rAm
Trim Level: sLt
Color: SiLvEr
Rep:54
speeddemon38b will become famous soon enough
nice write up, am having a bit trouble putting on mine, but ill follow what you did and it should come out great as it looks on yours
Old 05-17-2010, 03:24 PM
Trim Level: sxt
Rep:197
it's a snug fit - luckily the retainer strip on the top of the bumper and top torx bolts on each side hold everything in place in order to drill the two other mounting holes.
if you need any additional pics or help, feel free to pm me. i've fit the srt over chrome on two trucks that same way
Old 05-17-2010, 03:32 PM
Trim Level: sLt
Color: SiLvEr
Rep:54
if i need help ill pm you, appreciate the assistance, thanx
