Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 05-13-2010, 06:43 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
Default factory srt start button install
first take care of the the trim ring, i used the cig lighter ring - i used a large cone shaped grinder bit in a drill to open out the diameter cleanly and cut the most of the back off so the trim ring wouldn't interfere with the switch.
for the switch mounting, first push the button down and stick a toothpick in the side to hold it down. then lightly sand the black housing and corresponding area on the dash piece. get some industrial plastic 2-part epoxy and put a light film around the face of the switch (careful to not get any on the button)
fit the switch so the button lines up with the middle of the hole. let it dry for an hour. then mix a little more epoxy and build a bead around the perimeter of the switch. when dry pull the toothpick, test fit the trim ring - make any adjustments and epoxy it in. mine has held strong for 2 years now
for wiring ( i was lucky enough to get the factory plug and a short pigtail)
i'll try to find which 2 terminals you hook up to. hook the existing hot wire from the cigarette lighter to one terminal. splicing into the large yellow wire under the column, route a wire from under the steering column to the other terminal on the switch - use a test light to make sure you are tapping into the right wire.
button it all up and pretend you have an srt-10
Old 05-13-2010, 07:33 AM
iRESQu iRESQu is offline
Rep:2217
Very nice job. Thank you so much. Pics are always a plus!
Old 05-13-2010, 07:41 AM
Rep:1625
Nice write-up, thanks!!
Old 05-13-2010, 09:24 AM
Patriotblue07's Avatar
Patriotblue07 Patriotblue07 is offline
Vehicle: 2007 Dodge Ram 5.7L
Rep:16
Patriotblue07 is on a distinguished road
Thats outstanding. Where did you get the button?
Old 05-13-2010, 11:22 AM
Trim Level: sxt
Rep:197
i got it from a junkyard in jersey. they were partig out an srt. got the instrument cluster and start button.
Old 05-13-2010, 10:39 PM
Nice mod .
Old 05-13-2010, 11:12 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
they were parting out an SRT!?!?!?
I think I just cried a little.
Man would I love to find one of those in a yard...lol
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 05-14-2010, 12:19 AM
Trim Level: sxt
Rep:197
they had just gotten it in - someone already robbed the rear end but the interior was complete... except for the shift knob
Old 05-14-2010, 12:27 AM
I push the skinny pedal
Rep:3277
And the engine?
Kurtis
Old 05-14-2010, 12:33 AM
2007Ram1500's Avatar
2007Ram1500 2007Ram1500 is offline
Vehicle: 2007 Dodge Ram 1500 4.7
Color: Grey
Rep:63
2007Ram1500 will become famous soon enough
seen somebody selling SRT engine and Tranny (Auto)
for 7,000
