3500 fifth wheel install - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 05-14-2010, 09:04 AM
tbart16 tbart16 is offline
Vehicle: 2005 3500 Crew Cab
tbart16 is on a distinguished road
Default 3500 fifth wheel install
Anyone install a fifth wheel in a 3500 HD just lookin for tips or tricks thanks
Yeah its got a Hemi Yeah i know the cummins has more torque Yada yada yada........
Old 05-14-2010, 09:16 AM
khuman's Avatar
khuman khuman is offline
Vehicle: 2004 Ram 1500 Quad Cab
Rep:41
khuman is on a distinguished road
Default Not 3500 but 2500
I helped my cousin install a fifth wheel hitch in his 04' 2500. Also helped install one in two of my dad's trucks (F150 and F250). The main thing with any fifth wheel is checking, and rechecking your allignment and measurements.
Few questions:
Is the hitch a slider or static hitch?
Did your hitch come with rails?
Also are you using the install bracket kit or are you welding or both?
If you are using the install bracket kit things will be somewhat easier because it will give you the locations on your frame rails to mount the brackets, from there you drill up and install your rails (if you are using rails).
Hope this helps some. If you have other questions feel free to throw them out and I'll do my best to tell you what we did.
Old 05-14-2010, 09:26 AM
I've done 2 fords I was just curious because of the boxed frame and overload springs
Old 05-14-2010, 09:32 AM
khuman's Avatar
Rep:41
Well my cousing might have used an explicative or two in getting the things inside the box frame, but other than that things went pretty routine.
Old 05-14-2010, 09:45 AM
Appaloosa Appaloosa is offline
Vehicle: 2015 Outdoorsman C/C 1500 4x4
Trim Level: Outdoorsman
Color: Dark Blue
Appaloosa is on a distinguished road
Default Hitches
I have a 2500 not a 3500 but I used a B&W turnover ball set up. It installed in about 4 hours... I was really taking my time. the only cutting was to trim a corner out of the sheet metal under the box and to drill in a 3" hole for the ball in the deck of the box. It is a real sweet system. When I bought it was also the cheapest. They also have an adapter that you can use to hook up the other style of 5th wheel.
Good luck
Old 05-14-2010, 12:19 PM
thanks guys I have the existing fifth wheel from my previous truck I am actually going to pick up an "easy" install kit so we'll see how that works out I will try to get some pics up Monday
Old 05-17-2010, 08:00 AM
6 hours later fifth wheel in. It was absolutly horrible. Everything that could have gone wrong, went wrong the boxed frame was a bugger to work with ,but the hitch is in tonite I am going to tackle the front mount hitch.
