View Poll Results: What should i do?
Spend the $700.00 - $900.00 to fix it? 4 80.00%
Go to the dealer ship about the extended warranty? 1 20.00%
Trade it in, and look at a new truck? 0 0%
Voters: 5. You may not vote on this poll
Old 05-14-2010, 09:34 AM
Bad07hemi's Avatar
Bad07hemi Bad07hemi is offline
Vehicle: 2011 Dodge Ram 1500 5.7 Hemi
Rep:17
Bad07hemi is on a distinguished road
Send a message via AIM to Bad07hemi Send a message via Yahoo to Bad07hemi
Default What should i do?
Let's start out. I have a 2007 Dodge Ram 1500 5.7L Hemi 4x4. Recently for the past month or so i have been noticing a coolant leak. I didn't have time till yesterday to take it to a shop and be checked over to see what it was or what was causing it to leak. I made sure all the coolant levels were good everyday, so damage was done. I took it to the shop yesterday, and here it is something to do with the timing cover leaking So in other words they would have to take apart the hole front half of the motor to fix it, along with replacing a few others like the water pump, and thermostat. Its going to be like an $700.00 - $900.00 job to fix it. Unfortunately my warranty is up, its been up since 36k since i bought the truck used. I'm looking for some ideas. (1) Show i suck it up, pay the 7-9 hundred bucks to fix it? (2) Go to the dealership where i bought it from, and see if i can get an extended warranty? (3) Trade the thing in, and get a new truck? I'm looking for honestly and most realistic ideas. Let me know what you guys think? Thanks Andrew. H
Bama Performance & Hemifever Custom Tuning, Diablosport i2, K&N Blackhawk CAI, Magnaflow Y-Pipe, Hell Bent Steel 2.5 Leveling Kit, and Window Tint
Old 05-14-2010, 09:47 AM
Resident Technician
Rep:1915
I've never seen a Hemi leak anywhere other than the water pump weep hole. Get a second opinion first.
Old 05-14-2010, 10:22 AM
Fix it but get a second opinion first.
Your truck is worth the repair!
Old 05-14-2010, 10:45 AM
Rep:1625
I agree, your truck is worth it
Old 05-14-2010, 11:30 AM
Bad07hemi's Avatar
Rep:17
I agree to, i mean i love this truck. Hasn't had major issues other than this. Im just worried that once i fix this, other stuff will start to happen. JMO
Old 05-14-2010, 12:11 PM
droshemiram's Avatar
droshemiram droshemiram is offline
Vehicle: 03 dodge ram HEMI
Color: atlantic blue
Rep:89
droshemiram will become famous soon enough
If you do the work you should put a cam in since your already in there now that would be worth if.
Old 05-14-2010, 12:16 PM
RMBLEBee2392's Avatar
RMBLEBee2392 RMBLEBee2392 is offline
Vehicle: 05 RC/SB 4x4
Trim Level: Rumble Bee
Color: Solar Yellow
Rep:34
RMBLEBee2392 is on a distinguished road
I had a coolant leak once. The t-stat seal blew out and allowed it to leak at random. Was strange as it didnt do it all the time. The seal just had a small flat spot on it that was allowing it to leak. Changed the t-stat and it went away. could try that.
Old 05-14-2010, 12:34 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I hear were you are coming from///////What if? Honestly i would fix the problem.......If it is $700 to $900 thats not bad knowadays. But i agree with everyone else..Second opinion a definate....Then go from there. No problems till now..........fix it and keep it. You wouldnt get much on a trade in that shape anyway.JMO
Old 05-14-2010, 01:19 PM
Bad07hemi's Avatar
Rep:17
I hear you on that. That's the thing it only leaks like a river when i first start it up. Once it warms up, it doesn't leak at all. Only when the first start happens.
Old 05-14-2010, 01:35 PM
bones64's Avatar
Rep:659
It is sounding more like a tstat or pump to me.............Get a second opinion for sure.
