Old 05-14-2010, 09:51 PM
20ram08's Avatar
20ram08 20ram08 is offline
Vehicle: 2008 Dodge Ram
20ram08 is on a distinguished road
Default Installed K & N intake, Getting worse MPG...HELP!
I installed the K & N kit about a two weeks ago. Before the install, I was getting around 14-15 city and 18-20 highway. After driving city for a week, I got around 11-12 MPG and just today got 17 MPG on the highway, wtf!. At worst, I figured I would get the same mpg, in hopes of increasing the fuel economy. I've already cleaned the IAT sensor or whatnot with the proper cleaner, so no, a dirty sensor is not the problem. Has anyone heard of cold air intakes resulting in worse MPG's? I'm also thinking about purchasing a Bully Dog tuner, do you think this would help the gas mileage at all?
Old 05-14-2010, 09:57 PM
Do you have an exhaust system? If not, you aren't getting any benefit from the CAI. More air in needs more air out to improve efficiency.
That and trim some lead off your right foot.
Old 05-14-2010, 10:21 PM
Rep:1625
Well said MADDOG
Old 05-14-2010, 10:41 PM
20ram08's Avatar
good point, I'll probably get a cat back soon. I was just not expecting to get worse gas mileage from the intake.
Old 05-14-2010, 10:43 PM
Well, when you have more air coming in, it does lean out the engine a bit and these HEMI's have a very conservative knock retard program. It pulls timing and fuel, then, when the knock stops it adds it back...it's like getting on and off the throttle all the time but not as noticeable as it does this in milliseconds.
Get a catback on when you can, then a programmer that can help you fine tune your air/fuel ratios.
Old 05-14-2010, 10:53 PM
khuman's Avatar
khuman khuman is offline
Vehicle: 2004 Ram 1500 Quad Cab
Rep:41
khuman is on a distinguished road
I have a 04 with the 4.7. I added the K&N CAI and my mileage has improved. However I also have a PowerAid throttle body spacer. I'm actually up 2 MPG. Maybe even a little more than that since I added duals today.
Old 07-12-2010, 12:25 AM
CamoBoy34 CamoBoy34 is offline
Vehicle: 2004.5 Dodge Ram 2500
Rep:12
CamoBoy34 is on a distinguished road
i had a buddy have a shop put a CAI on his 2008 dodge deisel and they put the air intake of air flow sensor in backwards and it made the truck get bad MPG too. so you might want to check that
Old 07-12-2010, 12:46 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
the exhaust needs to be freed up a bit - all intake and no exhaust is like going to an eating contest constipated...
Old 07-12-2010, 08:51 PM
jayhkr's Avatar
jayhkr jayhkr is offline
Vehicle: 2006 Dodge Ram SLT 4x4
Color: Atlantic Pearl Blue Metallic
Rep:75
jayhkr will become famous soon enough
Send a message via ICQ to jayhkr
How exactly does something like this happen? My air flow sensor can only go in to the hole one way. Just curious.
Old 07-12-2010, 11:52 PM
Rep:12
the mass air flow sensor was put back in backwards. i dont know how it was done but and he took the truck back and they flipped it around and it made the truck run alot better
bully dog, cold air intake, gas mileage, k & n, mpg
