Old 05-15-2010, 02:00 PM
Reaver33's Avatar
Reaver33 Reaver33 is offline
Vehicle: 2014 Ram 3500 MegaCab
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Reaver33 is on a distinguished road
Default High AC pressure no cold????? wtf?
Hooked up a gauge and it read 105psi. Had that removed and new refrigerant put in the lp side. Vents blow like crazy but it's all hot air. Compressor doesn't seem to be kicking on either. Do I need a new compressor?
Old 05-15-2010, 02:26 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Exclamation
What side was reading 105psi ?? If it's the high side it sounds like you may need more refrigerant. In order to get the compressor to come on you need to have enough refrigerant in the system. When the system is properly charged the low side should be around 30psi and the high side around 150psi with the compressor running. Be very careful not to overcharge. You need to slowly put refrigerant into the low side until the low (suction) pipe entering the compressor starts to get cold. (thats the side coming from the evaporater and is larger in size). Of course the compressor needs to be turning before the suction side will start to get cold. As you put refrigerant into the low side the compressor should start to cycle on and off. If this does not happen something else may be at fault.
Old 05-15-2010, 04:31 PM
Reaver33's Avatar
Ok, the compressor was me just being a dumb ass. I thought the AC button was on and it wasn't. As soon as I saw it wasn't on I turned it on and the compressor engaged no problem. I put a can in and discovered my next issue. The two vents on the drivers side are much cooler now, however the passenger vents are still warm. And just so nobody asks this truck isn't equipped with dual climate control!! LOL!
Old 05-15-2010, 06:59 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
There is another post that mentions problems with the blend and mode doors, located here http://www.ramforumz.com/showthread....highlight=door. This might be your problem.
