Lifting Questions - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 05-15-2010, 08:39 PM
01RAMguy's Avatar
01RAMguy 01RAMguy is offline
Vehicle: 2001 Ram 1500 club 4x4 5.9 v8
01RAMguy is on a distinguished road
Question Lifting Questions
I have a 2001 Ram 1500 with a leveling kit and have 34in tires. I'm looking to get more clearance so I was planning to get 2in lift coil springs with the leveling kit and a 3in block lift in the back, then upgrade all 4 shocks. Will i have issues with anything because I'm not getting a full suspension lift kit?
Old 05-15-2010, 08:46 PM
ScatPak07's Avatar
Rep:970
You may have some issues with the 4x4. I had the problem of the front half shafts being on too much of an angle and the truck would vibrate when it 4x4. You may have to lower the front diff a little to avoid this. It may not happen you should look at them and see how much play they have.
Other stuff like getting the steering extension. Just check out what a lift kit comes with and make judgment calls on that! Cause whatever they have you may need to make the truck run smoothly!
Old 05-15-2010, 11:11 PM
01RAMguy's Avatar
I was looking at the full lift kits and might just go with one of them because it is my daily driver and want it to run smoothly.
