shifting problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 05-16-2010, 09:09 PM
jimmy14 jimmy14 is offline
Vehicle: 2 x 2010 Rams. Reg and Quad
Trim Level: 2 x ST
Color: Grey
jimmy14 is on a distinguished road
Default shifting problem
My son has a 1996 model that is intermittantly not shifting properly. At takeoff, it shifts and gains speed as it is supposed to, but it will not shift into overdrive and does about 50 mph at a little under 3000 rpm. It does it sometimes and sometimes it doesn't, with no common denominator. I was wondering if there is a common problem that would be a good start point. I don't know if there is a solenoid, valve, or switch that might be stuck, causing it to do this. Obviously, it is a 5.2L, automatic tranny, with about 120,000 miles. He had the tranny fluid changed and tranny flushed about a month or so before it started doing this.
Thanks in advance,
Jim
