Old 05-18-2010, 06:02 AM
rlc0939's Avatar
rlc0939 rlc0939 is offline
Location: Hueytown, Alabama. That is about 20 miles Southwest of Birmingham
Vehicle: 2008 Dodge Ram 1500 Quadcab
Trim Level: ST w/Big Horn Pkg.
rlc0939 is on a distinguished road
Default After the Gas Milage
I have the 3.92 gears now. I have already installed a magnaflo 3" in and out, CAi and the dioblo programer. I have run all 3 canned tunes with the best pereformance on high octang setting. How bad will it effect the pulling power of my truck if I dropped to 3.22 or 3.40 gears. I am not much on hot rodding. But I will pull a light tractor some times. honest opinion worth the investment. My trucks rpm ranges about 2200 @ about 73mph. I later rode in a Z-71 offroad chevy. He was pulling like 1600 rpm for same speed and his truck got about 3 mpg better milage
Help me out making this decision
AEM CAI, Magnaflow Exhaust, Diablosport Predator
Old 05-18-2010, 09:38 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
What size rims/tires do you have? If all you are trying to do is knock down your RPMs then a taller tire would help out. There are online RPM calculators that will help determine what tire or gear you can run based on your desired RPM or speed. Your 5th gear ratio is 0.67.
The next gear choice down is a 3.55 btw.
Old 05-19-2010, 07:19 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
The chev is a 5.3 litre ...if not even smaller proly doesnt have 20" chromes and a lighter truck. To be honest man if you drive a hemi and have to complain about mileage this truck is not for you.
Old 05-19-2010, 07:55 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Yes you can't compare two different makes and models without giving some other information!! do you have 20" wheels? if yes the stock tire size is 33" the chevy Z-71 prob has 16" on it with like a 30" tire....that alone in rolling mass would make a huge difference in the MPG...Same with the engine size...what was it?
Also by looking in your profile you have an 08, that has MDS..did you disable it with the programmer?? not familiar with the MDS but if your cruising at 73MPH should it not be kicking in an running on 4 cylinders?
Also unless you spend all your time on the highway/freeway i dont think going to a lower gear will help you out...it will put your acceleration into the tank for a little more top end speed... between the price of gears, and all that you would probably come out losing...especially when you start towing!!
if it make you feel better i get 10.6 MPG
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 05-22-2010, 12:06 AM
Raptor1000R's Avatar
Raptor1000R Raptor1000R is offline
Vehicle: 2010 Ram 1500 4x4 Sport Crew
Trim Level: Sport, buckets, RER
Color: bright white
Raptor1000R is on a distinguished road
I'm 100% with you guys, good point Ruffian11! If you want to trade for my 3.55's I'll trade you in a heart beat! I'm really not sure it is worth the expense/effort. If you drive like a girl and keep it <70mph, you will get decent mileage. Add a cheap car to your garage if you need great mileage!
I went from 3.55's to 4.10's in my F-150 and it made 1mpg better in town, but 1mpg worse on the highway. The biggest difference was I had a lot more pulling power from 0-80mph. I honestly think you'll be upset with anything taller than 3.55's if you pull anything from time to time. Try a 34" tire and see if it helps ya any. I personally think the 3.92's are the best all around for the 4Gen Hemi's. Just my 2 cents!
Ruffian11, fyi, the MDS doesn't operate much at all unless on my truck w/ 3.55's unless your maintaining 55mph or less on a level grade and no heavy headwind. I did see 0.5mpg avg. difference on 2 tanks when I disabled it, as a test, so I can say it honestly works, though it doesn't seem to operate much.
2010,15004x4,Hemi,Sport,White,Crew,CAI,Predator,Li ne-X,Truxedo Lo Pro,2"level kit,PE Powergate
Old 05-23-2010, 01:08 AM
HORNYHEMI's Avatar
HORNYHEMI HORNYHEMI is offline
Rep:16
HORNYHEMI is on a distinguished road
Changing gears isnt gonna change much mileage. Just remember when you drop your rpms your working your way out of your powerband and causing your motor to work harder for the same output thus requring more gas. Dont put a bigger tire on in to change your gearing. They weight difference in the bigger/heavier tire will cause your mileage to decrease even more. As for the MDS, just shut it off, I get better mileage not running MDS highway then running it.
Old 05-23-2010, 01:10 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
get 4.56 like me from 3.92
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 05-23-2010, 01:17 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
How did you determine that the Z71 got better mileage?
Did the owner tell you....or did you actually check and witness it yourself.?
Have to ask....I have a couple of 'non-Dodge' friends, and have heard the claims, but no one can produce the paperwork. Also, on a 3500km trip, they all got better mileage than I did, but I paid less for fuel on the trip. Guess the gas pump liked the Dodge so much, it changed it's price...just for me!
brad
Interested in one of my mods?
Old 05-23-2010, 01:47 AM
Trim Level: st
Color: silver
Rep:68
to lazy to read Get gears and stop crying about gas lol
