Old 05-22-2010, 08:26 PM
BigBlueEdge BigBlueEdge is offline
Vehicle: 2010 RAM 1500 Sport Hemi
BigBlueEdge is on a distinguished road
Originally Posted by LadyRam View Post
In the bottom pic, what is just above the "P"
The (P) parking brake symbol? Above it is the trailer brake controller.
Rob
Old 05-22-2010, 11:11 PM
hpc3 hpc3 is offline
Vehicle: 2010 Ram 1500 Laramie Crew 4x4
Color: Inferno on Slate
Rep:44
hpc3 is on a distinguished road
Send a message via AIM to hpc3
Default Like it! I sometimes wish I would have ordered the 17"s
Originally Posted by Indeepcamo View Post
Here are a few pics for you
Attachment 7188
Attachment 7189
KOs in 305/55/20 are $380 EACH! Ouch. Welp, maybe in a month or two. I want to get the front leveled first and would like to get the Mopar version of the Superlift 2.5" kit if it ever becomes real.
2010 Ram Laramie Crew 4x4, Inferno(mono) on Slate, All options, including BigSloshiTank
Old 05-23-2010, 10:58 AM
Rep:44
Default Badges came from my local dealer... had them in stock funny enough.
I do think my black sport looks pretty good, here is a pic with my Leer 700 on. You mentioned that those challenger HEMI badges you put on were $5, where did you get them ? Also, the RAM and HEMI side badges, were they very difficult to remove ? Don't want to damage my paint, LOL. Any advice would be appreciated.
Removing the stockers isn't hard but the tape can be a PITA sometimes, and Dodge uses a LOT of tape to hold these on. You'll need a warm day, a rigid plastic trim tool(available at Harbor Freight for ~$6 for a set of 5 in various shapes/types) and some Uni-Solve or other mild adhesive remover to get the goo off. I like the Uni-Solve since its skin safe and good at breaking down adhesives. If you haven't seen Uni-Solve remover before look for it at Nursing or Medical Supply stores(eBay has it for ~$10 per 8oz. You'll need maybe 2oz to do both sides).
On a warm day(75 deg F or more) take the trim tool, rounded side toward the truck/paint and wedge it gently from the top of the badge down into the tape/foam portion behind it. Try to split the foam in 1/2, that way you're not directly on the paint(and don't worry too much about scratches as the adhesive is really hard on the tape). Work across the top of the badge until it begins to bend downward. You can usually pull it off at this point. Hopefully you'll get lucky and some of the tape will come with it. I wasn't so lucky and the majority of the tape stayed on the truck. You can use the trim stick to push the tape into "balls" or chunks and then peel it off from here. Be careful to scrape in an angle with the plane of the panel and not perpendicular to it. Oh, don't use heat if you can avoid it. It may be necessary if you're in a cold location but if you get the tape too hot it becomes tough and gooey and almost impossible to roll or push off.
Once all the letters/badges are off use the Uni-Solve on a towel or cloth to rub onto the remaining foam and adhesive. Coat it maybe 2x and let it sit for a few min. Repeat the Uni-Solve again and you'll see the foam parts pilling and falling off. Keep working on the adhesive and it will eventually come off. I used some liquid carnuba(The Wax Shop) wax to polish and finish cleaning... there were no scratches but this wax helps dissolve tar/road-grime spots and leaves no residue.
I'm not sure if there is a sealer or wax on it from the factory but I'll wax it good in a month or two for a finishing touch. Doesn't seem to need anything yet.
Old 05-23-2010, 03:35 PM
coolidge coolidge is online now
Vehicle: 2014 Ram 1500 CC 5.7L 3.92
Trim Level: Big Horn CC 6'4" box
Color: Maximum Steel
Rep:16
coolidge is on a distinguished road
I'm a center console hater but the Laramie mono is badass! Nice ride!
Old 05-24-2010, 12:58 PM
Rep:44
Default Grille and VES screen are here. Grille pic for reference:
Sorry for the color, big cloud in the background and I'm still learning my camera. Didn't realize it was so dark in the pic.
I'll install the VES once my AllGig gets here. Fender flares and steps should be done/here tomorrow. Exhaust is supposed to arrive today. Will update.
