Help!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-19-2010, 08:22 PM
gdeezy's Avatar
gdeezy gdeezy is offline
Vehicle: '97 Ram
Trim Level: Blackin' Out
Rep:76
gdeezy will become famous soon enough
Send a message via AIM to gdeezy
Default Help!!!
So my trucks been acting horrible ever since I towed a 30' travel trailer across 3 states, and I figured I'd go ahead and try to change the distributor cap and plugs and wires, as well as the rotor. Welllll, after 4 hours or so, that was done, but then I started up the truck, it backfires, and has NO power to the rpms. I'm assuming this is because my dumb @$$ decided to use a marker to mark the wire order on them, and it wiped off! So I guess the order of the wires on the cap are wrong.. Now, I know the firing order of the cap, but does anyone have a diagram or anything to show what # each cylinder is, from the front of the hood to the back? I figured it was 1-2 in the farthest back, and 3-4 the next row, 5-6, etc etc. Am I wrong?
Old 05-19-2010, 09:03 PM
Ram98's Avatar
Ram98 Ram98 is offline
Vehicle: '98 Ram 1500 , 2004 Rumble Bee
Trim Level: Sport,Rumble Bee
Color: Blue, Yellow
Rep:28
Ram98 is on a distinguished road
From front of hood drivers side is 1-3-5-7 and passengers 2-4-6-8. Firing order is 1-8-4-3-6-5-7-2 clockwise. On distributor No 1 is just before mounting screw on passengers side. Hope this helps.
98 Ram 1500 Sport 4x4 5.9L
2004 Ram 1500 4x4 Rumble Bee
Old 05-19-2010, 09:18 PM
Sounds like it .
Old 05-19-2010, 09:20 PM
ScatPak07's Avatar
Rep:970
Looks like you got taken care of! Hope that was the answer you were looking for! Let us know if anythng else is wrong and we will help you out!
Old 05-19-2010, 11:27 PM
gdeezy's Avatar
Vehicle: '97 Ram
Rep:76
Thanks, I'll have to try that tomorrow. No wonder my truck sounded so mad, I had it completely backwards! haha.
Old 05-20-2010, 08:22 PM
gdeezy's Avatar
Vehicle: '97 Ram
Rep:76
Welp, I put them the way they should be, still no luck.. The check engine light isn't on anymore though! I'm starting to thing I put the distributor cap on wrong, and the screw isn't lined up on one side, since that's the only thing left that couldve happened. Any ideas?
Old 05-22-2010, 11:06 AM
gdeezy's Avatar
Vehicle: '97 Ram
Rep:76
Distributor cap turned out to be on right, but I think I messed up the order again. I went ahead and bought new wires and plugs, and was in the process of replacing them, got the new plugs and wires put in fine on 1, 3, 5, and 7, but when I tried to pull off the wire for cylinder 2, the wire pulled completely out of the connector that connects to the spark plug. So now I'm stuck due to a lack of tools, with a rubber boot with no wire stuck on one of my cylinders. I think I'm gonna call a mechanic. Lol.
Old 05-22-2010, 08:42 PM
gdeezy's Avatar
Vehicle: '97 Ram
Rep:76
Crisis averted! She's runnin' like a beauty now. Turns out I had the cylinders backwards, i thought 1357 were on the passenger side. And they were counterclockwise too. I'm a dummy., Lol.
Old 05-23-2010, 08:18 PM
Ram98's Avatar
Color: Blue, Yellow
Rep:28
Glad things worked out for you
Old 08-27-2010, 01:26 PM
St. Ram's Avatar
St. Ram St. Ram is offline
Vehicle: 1997 Dodge Ram
Trim Level: SLT Laramie
St. Ram is on a distinguished road
Does anyone know of an easier way to get to the dist cap? I can barely even see mine. I wanna change my plugs and wires but I am too freakin short to see where the wires are going behind the engine.
