Old 08-08-2011, 04:44 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
well what was a few minute job turned into a couple hour job. i had a spare tps so i figured id drill out the metal sleeves a lil, tried it, no big difference, so i figured phuck it ill knock em out, got one out, tried gettin the other one out and the front came off,,,phuck i broke it, so i dick around with it and got it workin again, so i siliconed the hell out of it, figured my luck ill be cruisin and abusin it and the front would fall off, so i cut a lil piece of aluminum (left over from the light bracket) to span from the screws and hold it in place, now i got .77/.78 and 3.98-4.00 at WOT, test drove it and seems more responsive, so im happy
Old 09-02-2011, 06:26 PM
OlGreg OlGreg is offline
Vehicle: 1995 Dodge Ram
Color: Silver/Burgandy
OlGreg is on a distinguished road
not sure what you're adjusting? but I can't rotate my tps one way or the other to change voltage. Are you adjusting the butterfly?
Old 09-03-2011, 12:29 AM
mr.lopar's Avatar
Rep:192
nope the tps. did you loosin the screws? there aint much movement in it, unless you knock out the lil metal sleaves, which you gotta be careful or you can break it
Old 09-03-2011, 08:53 AM
cj5orion's Avatar
cj5orion cj5orion is offline
Vehicle: '98 ram 1500,mag,4-whl,lifted
Color: green
cj5orion is on a distinguished road
any 5.9 ? how bout the 98 1500's ?
'98 ram 1500,skyjacker lift,BFG Mudders,Magnaflow exhaust
aaaaaand 1 choc lab----bird dog !
Old 09-03-2011, 11:16 AM
mr.lopar's Avatar
Rep:192
any 5.2s/5.9s from 94 up. did this on my 99 5.2
Old 09-03-2011, 08:43 PM
cj5orion's Avatar
Color: green
I gotta try this,,,right now 8- mpg !!!!! YIKES !!
Old 09-05-2011, 06:05 PM
Serrilion's Avatar
Serrilion Serrilion is offline
Vehicle: 2009 Lancer TURBO
Trim Level: ES Sport
Color: Graphite Gray
Serrilion is on a distinguished road
Send a message via AIM to Serrilion Send a message via MSN to Serrilion Send a message via Yahoo to Serrilion
I did a write up for this if ya wish to check it out chaps
http://www.ramforumz.com/showthread....583#post606583
I was bored!
Old 09-22-2011, 04:50 PM
JustiNeal 97's Avatar
JustiNeal 97 JustiNeal 97 is offline
Vehicle: 1997 Dodge Ram 1500 4WD
JustiNeal 97 is on a distinguished road
Hey I tried doing this a few days ago and when I tried doing it I accidentally took the TPS off and when I did that i tried putting it back on after i got it back on i took it for a spin around the block and noticed that my throttle pedal was almost all the way to the floor I couldnt get my truck to go faster than like 35 MPH and i was putting all of my weight into it lol.. Then i figured that i needed a new TPS so i ordered one and got it today and installed it but the same thing happened im still not getting any good throttle response. Any help would be awesome...because i really wanna go play in the mud lol..
Old 09-23-2011, 01:14 AM
mr.lopar's Avatar
Rep:192
check your throttle cables, i had the samething happen, and the throttle cable on the front side wasnt around the slider on the bracket
Old 09-23-2011, 05:57 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Yeah the throttle cable probably came loose.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
